Compression in CISCO Routers
timmysyed
Can we apply Stacker/Predictor compression command in CISCO CLI using CISCO Packet Tracer ?
I want to generate Traffic and apply compression command to evaluate. Please advise.
Timmy Syed
Jaderson Pessoa
Dear timmysyed,
Some features doens't work on packet tracer,i suggest you to use a GNS3
Jaderson Pessoa
*** Rate All Helpful Responses ***
Jaderson Pessoa
Dear timmysyed,
Jaderson Pessoa
Dear Jaderson
Thank You for the reply. Yes agree GNS3 is better option. Appreciate your help.
thanks a lot guy.
Jaderson Pessoa
