04-12-2012 11:20 AM - edited 03-07-2019 06:05 AM
We are having problems with the connection between a router cisco 2811 and switch cisco 3750G.
The interface LAN of the router 2811 is Fastethernet configured with: speed 100 and duplex full.
The interface Gigabit ethernet ofr switch 3750G is configured with: speed: 100 and duplex full.
When we run the command: show interface fastethernet 0/1 at cisco router 2811 we can see a high level of dropped paquet:
ALi_Trujillo_61903#sh int fas
ALi_Trujillo_61903#sh int fastEthernet 0/1
FastEthernet0/1 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 0007.0e29.1849 (bia 0007.0e29.1849)
Description: LAN|Alicorp_TRujillo (PRincipal)|CD=61903
Internet address is 10.232.200.1/16
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 2/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 23:56:38
Input queue: 0/75/85576/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 279000 bits/sec, 321 packets/sec
5 minute output rate 827000 bits/sec, 281 packets/sec
33119734 packets input, 1176559562 bytes
Received 253084 broadcasts, 0 runts, 0 giants, 7243 throttles
1747057 input errors, 0 CRC, 0 frame, 0 overrun, 1747057 ignored
0 watchdog
30444207 packets output, 174170064 bytes, 0 underruns
8270 unknown protocol drops
0 lost carrier, 0 no carrier
ALi_Trujillo_61903#
ALi_Trujillo_61903#
But at the interface Gigabitethernet of 3750G does not appear any error, all is o.k.
The IOS of the router cisco 2811 is: c2800nm-adventerprisek9-mz.124-19b
Would you be mind telling me if we need to change the router to other models that support gigabit interface to resolve this problem?
Thanking in advance any suggestion.
Attn.
Roger Majo
Solved! Go to Solution.
04-18-2012 02:29 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Like Glen, your initial posting stats could indicate the 3750G is sending large bursts of traffic to the 2811 (small packets would be the most problematic). The 2811, although it has FastEthernet ports, does not guarantee 100 Mbps line-rate. What you may need to do is slow or pace the transmission rate from the 3750G to the 2811. Perhaps the simplest change you might try is to run this connection at 10 Mbps. Or, you can use QoS features on the 3750G to slow its transmission rate to the 2811.
As to whether a router with a gig interface would work better, really depends on the performance of the router itself. For example, the next larger model in the 2800 series, the 2821, offers gig interfaces but it too, I recall, doesn't even guarantee 100 Mbps line rates either but this kind of drop should decrease as that model is "faster". (BTW, the newer 2900 series are much "faster" for the same model level, i.e. a 2911 is much "faster" than a 2811.)
04-12-2012 12:43 PM
That probably means the switch is sending data to the router too fast for it too handle at times . A small router cannot handle traffic as fast as a switch can send it at times so you will see input errors and drops on the interface and why you dont see it on the switch side because it can handle it .
04-12-2012 03:14 PM
Can please post the output to the command "sh controll e fastEthernet 0/1". I have a strange feeling this is duplex mismatch error.
04-16-2012 04:35 PM
Hi Leolaohoo.
This is the show controllers fastethernet 0/1 output command:
ALi_Trujillo_61903#show controllers fastEthernet 0/1
Interface FastEthernet0/1
Hardware is MV96340
HWIDB: 457372D0, INSTANCE: 45738398, FASTSEND: 42D5B6E4, MCI_INDEX: 0
Aggregate MIB Counters
Rx Good Bytes: 2995076612677 Rx Good Frames: 8953615
Rx Bad Bytes: 0 Rx Bad Frames: 0
Rx Broadcast Frames: 54465 Rx Multicast Frames: 877820
Tx Good Bytes: 6522900318843 Tx Good Frames: 7062669
Tx Broadcast Frames: 1448 Tx Multicast Frames: 282
Rx+Tx Min-64B Frames: 7189388 Rx+Tx 65-127B Frames: 4746308
Rx+Tx 128-255B Frames: 1108680 Rx+Tx 256-511B Frames: 497751
Rx+Tx 512-1023B Frames: 281490 Rx+Tx 1024-MaxB Frames: 2192667
Rx Unrecog MAC Ctrl Frames: 0
Rx Good FC Frames: 0 Rx Bad FC Frames: 0
Rx Undersize Frames: 0 Rx Fragment Frames: 0
Rx Oversize Frames: 0 Rx Jabber Frames: 0
Rx MAC Errors: 0 Rx Bad CRCs: 0
Tx Collisions: 0 Tx Late Collisions: 0
PHY Registers
Register 0x00: 2100 780D 0040 61E4 0101 C1E1 000C 2001
Register 0x08: 0000 xxxx xxxx xxxx xxxx xxxx xxxx xxxx
Register 0x10: 1000 0300 0000 0000 0200 01C4 0200 0000
Register 0x18: 0037 000D 9F00 008A 0827 0000 0020 000B
PHY Control (0x00):
100MBPS FULLDUPLEX
PHY Status (0x01):
LINK_UP
Auto-Negotiation Advertisement (0x04):
100FD
Link Partner Ability (0x05):
100FD 100HD 10FD 10HD
Serial Management Interface Registers (0xB4002000)
PHYAR = 0x00002841 SMIR = 0x0FE2000B
EUDAR = 0x00000000 EUDIDR = 0x000000E0 EUICR = 0x00000010
EUIMR = 0x00000000 EUEAR = 0x00000000 EUIAER = 0x00000000
BAR0 = 0x00000E00 SR0 = 0x0FFF0000
BAR1 = 0x00000000 SR1 = 0x00000000
BAR2 = 0x00000000 SR2 = 0x00000000
BAR3 = 0x00000000 SR3 = 0x00000000
BAR4 = 0x00000000 SR4 = 0x00000000
BAR5 = 0x00000000 SR5 = 0x00000000
HARR0 = 0x00000000 HARR1 = 0x00000000
HARR2 = 0x00000000 HARR3 = 0x00000000
BARER = 0x0000003E EPAPR0 = 0x00000003 EPAPR1 = 0x00000003
Port Control Registers (0xB4002800)
PCR = 0x00000000 PCER = 0x00000000 MII = 0x00218823
GMII = 0x00000006 VLANET = 0x00008100 MACLO = 0x00001849
MACHI = 0x00070E29 SDCR = 0x01000009 DSCP0 = 0x00000000
DSCP1 = 0x00000000 DSCP2 = 0x00000000 DSCP3 = 0x00000000
DSCP4 = 0x00000000 DSCP5 = 0x00000000 DSCP6 = 0x00000000
PSCR = 0x012A260F VPT2P = 0x00000000 PSR = 0x00000426
TQCR = 0x00000000 TQFPC = 0x000000FF PTTBRC = 0x000003FF
MTU = 0x00000006 PMTBS = 0x0000FFFF ICR = 0x00000000
ICER = 0x00000000 IMR = 0xF807FFFF IMER = 0xFFFFFFFF
PRFUTR = 0x00000008 PTFUTR = 0x00000000 PMFSR = 0x00000040
PDFC = 0x00000000 POFC = 0x00000000 EUIAER = 0x00000000
CRDP0 = 0x0F4440A0 CRDP1 = 0x00000000 CRDP2 = 0x00000000
CRDP3 = 0x00000000 CRDP4 = 0x00000000 CRDP5 = 0x00000000
CRDP6 = 0x00000000 CRDP7 = 0x00000000 RQCR = 0x0003FE01
TCSDP = 0x0F4448F0 TCQDP0 = 0x0F4448F0 TCQDP1 = 0x00000000
TCQDP2 = 0x00000000 TCQDP3 = 0x00000000 TCQDP4 = 0x00000000
TCQDP5 = 0x00000000 TCQDP6 = 0x00000000 TCQDP7 = 0x00000000
TQTBCTR0 = 0x01CF20CA TQTBCFG0 = 0x03FFFFFF TQARCFG0 = 0x00000006
TQTBCTR1 = 0x0D169721 TQTBCFG1 = 0x03FFFFFF TQARCFG1 = 0x00000006
TQTBCTR2 = 0x32997ABA TQTBCFG2 = 0x03FFFFFF TQARCFG2 = 0x00000006
TQTBCTR3 = 0x16CBC160 TQTBCFG3 = 0x03FFFFFF TQARCFG3 = 0x00000006
TQTBCTR4 = 0x0FE974BF TQTBCFG4 = 0x03FFFFFF TQARCFG4 = 0x00000006
TQTBCTR5 = 0x06A76FB5 TQTBCFG5 = 0x03FFFFFF TQARCFG5 = 0x00000006
TQTBCTR6 = 0x159B5666 TQTBCFG6 = 0x03FFFFFF TQARCFG6 = 0x00000006
TQTBCTR7 = 0x21C76783 TQTBCFG7 = 0x03FFFFFF TQARCFG7 = 0x00000006
PTTBC = 0x3FFFDBF9
Hardware MAC Address Filters
Unicast Filter
[00-03] = 0x00000000 0x00000000 0x00000100 0x00000000
Special Multicast Filter
[00-03] = 0x00000000 0x00000000 0x00000000 0x00000000
[04-07] = 0x00000000 0x00000000 0x00000000 0x00000000
[08-11] = 0x00000000 0x00000000 0x00000000 0x00000000
[12-15] = 0x00000000 0x00000000 0x00000000 0x00000000
[16-19] = 0x00000000 0x00000000 0x00000000 0x00000000
[20-23] = 0x00000000 0x00000000 0x00000000 0x00000000
[24-27] = 0x00000000 0x00000000 0x00000000 0x00000000
[28-31] = 0x00000000 0x00000000 0x00000000 0x00000000
[32-35] = 0x00000000 0x00000000 0x00000000 0x00000000
[36-39] = 0x00000000 0x00000000 0x00000000 0x00000000
[40-43] = 0x00000000 0x00000000 0x00000000 0x00000000
[44-47] = 0x00000000 0x00000000 0x00000000 0x00000000
[48-51] = 0x00000000 0x00000000 0x00000000 0x00000000
[52-55] = 0x00000000 0x00000000 0x00000000 0x00000000
[56-59] = 0x00000000 0x00000000 0x00000000 0x00000000
[60-63] = 0x00000000 0x00000000 0x00000000 0x00000000
Other Multicast Filter
[48-51] = 0x00000000 0x00000000 0x00000000 0x00000100
Software MAC Address Filter (hash:length/addr/mask/hits)
0x000: 0 ffff.ffff.ffff 0000.0000.0000 1311060
0x047: 0 0007.0e29.1849 0000.0000.0000 0
0x0C0: 0 0100.0ccc.cccc 0000.0000.0000 22561
Software filtered frames: 390
Unicast overflow mode: 0
Multicast overflow mode: 1
Promiscuous mode: 0
Rx Rings
Rx Ring 0 Rx Ring 1
- size = 128 - size = 0
- head = 3 - head = 0
- shadow = 0x457387F8 - shadow = 0x00000000
- ring = 0x0F443C60 - ring = 0x00000000
- ring_malloc = 0x3F443C60 - ring_malloc = 0x00000000
Rx Ring 2 Rx Ring 3
- size = 0 - size = 0
- head = 0 - head = 0
- shadow = 0x00000000 - shadow = 0x00000000
- ring = 0x00000000 - ring = 0x00000000
- ring_malloc = 0x00000000 - ring_malloc = 0x00000000
Rx Ring 4 Rx Ring 5
Rx Ring 6 Rx Ring 7
Tx Rings
Tx Ring 0 Tx Ring 1
- head = 19 - head = 0
- tail = 19 - tail = 0
- usedtxds = 0 - usedtxds = 0
- framecnt = 0 - framecnt = 0
- shadow = 0x45738A2C - shadow = 0x00000000
- ring = 0x0F4444A0 - ring = 0x00000000
- ring_malloc = 0x3F4444A0 - ring_malloc = 0x00000000
Tx Ring 2 Tx Ring 3
- tail = 0 - tail = 0
Tx Ring 4 Tx Ring 5
Tx Ring 6 Tx Ring 7
Port Stopped: N
ALi_Trujillo_61903#
04-16-2012 04:51 PM
Thanks for the output but I think this is not what I was looking for. You missed the "e" between the word controllers and the interface.
04-17-2012 06:59 PM
The command do you mention does not exist:
ALi_Trujillo_61903#sh controll
ALi_Trujillo_61903#sh controllers ?
Async Async UART internal info
Async Async interface
E1 E1 controller internal state
FastEthernet FastEthernet IEEE 802.3
J1 J1 controller internal state
Serial Serial
T1 T1 controller internal state
T3 T3 controller internal state
XTagATM Extended Tag ATM interface
vsi VSI information
| Output modifiers
ALi_Trujillo_61903#sh controll e fas
ALi_Trujillo_61903#sh controll e ?
% Unrecognized command
ALi_Trujillo_61903#sh controll e1 fas
ALi_Trujillo_61903#sh controll e1 ?
| Output modifiers
ALi_Trujillo_61903#'
Can yu have another command, please?
Attn.
Roger Majo
04-17-2012 07:04 PM
Sorry, but can you run the command on the switch?
04-18-2012 11:38 AM
I am going to ask for the command to the switch administrator.
Thanking you in advance.
Attn.
Roger Majo
04-18-2012 02:29 AM
Disclaimer
Posting
