Config mode locked out until standby initializes
magdy fekry
I face this problem when trying to login on config mode at Cisco Catalyst 4510R+E Switch :
CORE>en
Password:
CORE#conf t
Enter configuration commands, one per line. End with CNTL/Z.
CORE(config)#
or is recovered from recovery mode if it is a virtual switch
Command execution is locked, Please try later.
CORE(config)#
CORE(config)#
CORE# sh module
Chassis Type : WS-C4510R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 48 1000BaseX SFP WS-X4748-SFP-E CAT2202L5DH
2 48 1000BaseX SFP WS-X4748-SFP-E CAT2202L5BV
3 48 10/100/1000BaseT EEE (RJ45) WS-X4748-RJ45-E CAT2204L14Z
4 48 10/100/1000BaseT EEE (RJ45) WS-X4748-RJ45-E CAT2204L14U
5 Supervisor
6 8 Sup 8-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP8-E CAT2204L2BM
M MAC addresses Hw Fw Sw Status
1 00be.7504.c280 to 00be.7504.c30f 1.0 Ok
2 00be.7504.b720 to 00be.7504.b74f 1.0 Ok
3 00be.7524.b348 to 00be.7524.b367 1.1 Ok
4 4c77.6dde.e8c9 to 4c77.6dde.e8f8 1.1 Ok
5 Unknown Unknown Unknown Other
6 4c77.6d35.8288 to 4c77.6d35.848f 1.3 15.1(1r)SG5 03.08.05.E Ok
Mod Redundancy role Operating mode Redundancy status
5 Standby Supervisor SSO Disabled
6 Active Supervisor SSO Active
System Failures:
Power Supply: bad/off (see 'show power')
i know that , this is a problem at specific module  " module 5"  , i try to disconnect it and connect it again but nothing new !     any other solution ??
4 Accepted Solutions
The only thing that might help you is find a way to get console port output via a serial cable. Try to leave it powered off for 20-30 minutes and then give it a go again with the serial cable.
If the SUP does't show anything you might try to change serial speed, it should be 9600 but it could have been changed to something else(actually you should be able to check this from the config (line console 0))
If you don't get anything in anyway you can try to creare a virtual session to module 5:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/31sga/configuration/guide/config/cli.html
Check out for "Virtual Console", make sure that you understand what you are doing with these commands as they need to be run on the active supervisor.
Last chance will be to open a TAC case
ADP
Matt Delony
Hello Magdy Fekry,
This error message is usually seen when standby sup is trying to reach RPR or SSO redundancy. It prevents config changes until standby sup is done syncing with active sup.
Is the standby sup trying to sync with active sup? You can check with "show redundancy" output.
So if the chassis has dual supervisor cards, then it's not going to impact anything.
But it is still wise to have a valid change window.
21 Replies 21
ADP_89
Are SUPS in slot 5 and 6 of the same type? Try to put a console cable on Module 5 and disconnect/connect it to see what it says during boot phase.
ADP
Hello dear ADP89 ,
when trying to connect console with module 5 nothing appear on screen !
Supervisor might be dead then, have you looked at the led status?
Cheers,
ADP
Led status isn't stable up/down !
Magdy
Check table 2 and table 3 here:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/hardware/configuration/notes/OL_29676.html
You probably can determine what's going on with the SUP.
ADP
OK ..
ADP, thanks for your time
You are more than welcome, remeber to mark this post as solved if you are happy with the answers and give helpful points to the answers that helped you.
Good luck with the SUP,
ADP
Of course your answers helped me thanks alot ,
but led status is Orange up/down at the table orange mean --> System boot or a diagnostic test is in progress.
any other solution or module must be replaced ?
ADP
Matt Delony
Hello Magdy Fekry,
Hello dear Matt Delony,
this is the output any solution can solve this issue without replacing this modules
CORE#show redundancy
Redundant System Information :
Available system uptime = 11 weeks, 4 days, 20 hours, 14 minutes
Switchovers system experienced = 1
Standby failures = 2
Last switchover reason = active unit failed
Hardware Mode = Duplex
Configured Redundancy Mode = Stateful Switchover
Operating Redundancy Mode = Stateful Switchover
Maintenance Mode = Disabled
Communications = Down Reason: Failure
Current Processor Information :
Active Location = slot 6
Current Software state = ACTIVE
Uptime in current state = 11 weeks, 5 days, 4 hours, 19 minutes
Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSALK9-M), Version 03.08.05.E RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Mon 18-Sep-17 07:14 by pr
BOOT = bootflash:cat4500es8-universalk9.SPA.03.08.05.E.152-4.E5.bin,1;
Configuration register = 0x2
Peer (slot: 5) information is not available because it is in 'DISABLED' state
This usually indicates that standby sup is in rommon mode or booting up.
Check if the standby sup is stuck in rommon or attempting to boot. You may need to access console port of slot 5 to check.
When try to access console at module 5 not responding & nothing appear on screen
That line card is dead.
