Config Multi VLANs on Dell Blade Server with Cisco 3032 Switch Blades
dohogue
We recently purchased a Dell PowerEdge M1000e Blade Server with 4 Cisco 3032 Blade Switches.
We have 2 4507 core switches.
The Blade Servers will have multiple NICs that may or may not be on separate VLANs. For example:
Server-1 NIC-1 will have IP of 172.17.4.20 NIC-2 will have IP of 172.17.5.20 and NIC-3 will have IP of 172.17.102.5
Server-2 All NICs will have IP in 172.17.100.0 255.255.252.0 netowrk
Server-3 NIC-1 will have IP of 172.17.4.30 NIC-2 will have IP of 172.17.6.00 and NIC-3 will have IP of 172.17.102.20
I have a total of 4 Cisco 3032 Blade Switches that I want to trunk and channel to the 4507's in a failover design that if I lose 1 of the 4507's or a 3032 I will not lose connectivity to any of the Blade Servers.
Would appreciate a discussion on the best design for this.
branfarm1
Level 4
Level 4
Hi there. I use something similar, albeit, with only 2 blade switches in a chassis.
You can pretty much think of the blade switches as standalone switches -- so draw your network diagram as if you had 4 2960's (or some other access switch of your choice).
For my implementation, all of my blade switches are connected to each core switch in a standard Triangle topology. I use STP priorities to ensure that the primary core switch is the STP root for each vlan, and I disble the internal links between the blade switches. Each switch carries all of the VLAN's (or at least has the ability to do so), and I trunk the Switch-server links and let the NIC drivers handle the teaming and trunking.
This setup has provided fantastic redundancy and fault-tolerance for me. Essentially, you'll end up with each server having 4 physical network connections. Depending on the capabilities of the NIC drivers, you can do load-balancing across all of the links or just do fault-tolerance (when only one link is active, with others in a standby mode).
Hope that helps,
--Brandon
Thanks.
So let me know if I am thinking right here.
Server-1 Nic-1 will communicate over port 1 of all 4 3032 switch modules
Server-1 Nic-2 will communicate over port w of all 4 3032 switch modules
etc..etc..
Is that correct?
I believe that each server will have 1 NIC mapped to a switch module:
Server1 - NIC 1 -- Port 1 of 3032A1
Server1 - NIC 2 -- Port 1 of 3032A2
I believe access to the B fabric requires an extra mezzanine card in each server. Once you have that, it will connect as:
Server1 - NIC 3 -- Port 1 of 3032B1
Server1 - NIC 4 -- Port 1 of 3032B2
There's a good whitepaper on Cisco blade switches and the Dell enclosure here:
http://www.cisco.com/en/US/prod/collateral/switches/ps6746/ps8742/ps8764/white_paper_c07-443792.pdf
