Configuration changes are locked
Ravindra Simpi
I am trying copy startup-config running-config
The above command is failing with an error.
User Access Verification
Password:
MLS-77-1>enable
Password:
MLS-77-1#copy startup-config running-config
% Copy to running-config failed because configuration changes are locked
And if I try the command after few seconds, it will be successful.
What can be the problem?
6 Replies 6
glen.grant
What model is this device and is it native or hybrid os ?? If its 6500 running hybrid then there is no write memory or copy run start commands , confgiurations are saved as soon as you enter the information . Just by looking at your prompt it looks like hybrid so there is no need to save any config it is saved automatically , but of course it is always smart to save a copy on a tftp server somewhere in case the hardware fails .
I am using 6509 with Image..
c6sup22-psv-mz.121-26.E5.bin
I think its the issue with u r access level privilages on the device.Can u confrim what level of access u have on this device.
Mahmood
Do a show mod command and post here and we can tell better . To me it looks your first post prompt is catos but I could be wrong.
MLS-77-1#sh mod
Mod Ports Card Type Model Serial No.
1 2 Catalyst 6000 supervisor 2 (Active) WS-X6K-S2U-MSFC2 SAL0749QEGC
2 2 Catalyst 6000 supervisor 2 (Standby) WS-X6K-S2U-MSFC2 SAL0749QEFW
3 48 48-port 10/100 mb RJ45 WS-X6148-RJ-45 SAL0749Q6YP
4 16 SFM-capable 16 port 10/100/1000mb RJ45 WS-X6516-GE-TX SAL0748Q5DP
6 0 2 port adapter FlexWAN WS-X6182-2PA SAD0710005F
Mod MAC addresses Hw Fw Sw Status
1 0006.d65d.afd8 to 0006.d65d.afd9 5.0 7.1(1) 12.1(26)E5 Ok
2 0009.1246.d664 to 0009.1246.d665 5.0 7.1(1) 12.1(26)E5 Ok
3 000e.3893.7780 to 000e.3893.77af 1.3 5.4(2) 8.5(0.9)TFW3 Ok
4 000e.38c3.dac0 to 000e.38c3.dacf 2.5 6.3(1) 8.5(0.9)TFW3 Ok
6 0008.7cd6.5180 to 0008.7cd6.51bf 1.5 12.1(26)E5 12.1(26)E5 Ok
Mod Sub-Module Model Serial Hw Status
1 Policy Feature Card 2 WS-F6K-PFC2 SAL0749QD34 3.4 Ok
1 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAL0749QBQ2 2.6 Ok
2 Policy Feature Card 2 WS-F6K-PFC2 SAL0747PZWP 3.4 Ok
2 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAL0749QBNY 2.6 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
4 Pass
6 Not Applicable
I think the reason for that error is because I am trying to run the command when both the active and standby card are trying to sync.
Jan 14 16:10:13.818 GMT: %PFREDUN-SP-6-ACTIVE: Standby initializing for R
PR-PLUS modesh
Jan 14 16:10:14.070 GMT: %PFINIT-SP-5-CONFIG_SYNC: Sync'ing the startup c
onfiguration to the standby Router mod
### here I run the command.. ##########
####### here the sync is completed #######
Jan 14 16:11:14.607 GMT: %SNMP-5-MODULETRAP: Module 1 [Up] Trap
Jan 14 16:11:14.091 GMT: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimu
m Online Diagnostics...
Jan 14 16:11:14.091 GMT: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online Diag
nostics
Jan 14 16:11:14.503 GMT: %OIR-SP-6-INSCARD: Card inserted in slot 1, inte
rfaces are now onlinesh mod
00:00:08: %OIR-SP-STDBY-6-CONSOLE: Changing console ownership to route pr
ocessor
00:00:42: %PFREDUN-SP-STDBY-6-STANDBY: Initializing for RPR-PLUS mode
00:00:47: %SPANTREE-SP-STDBY-5-EXTENDED_SYSID: Extended SysId enabled for
type vlan
00:00:47: SP-STDBY: SP: Currently running ROMMON from S (Gold) region
00:00:58: %DIAG-SP-STDBY-6-RUN_MINIMUM: Module 1: Running Minimum Online
Diagnostics...
00:01:36: %DIAG-SP-STDBY-6-DIAG_OK: Module 1: Passed Online Diagnostics
00:01:50: %SW_VLAN-SP-STDBY-6-VT
If I try to save configs before or after this sync process then I will be able to save the configs properly.
Actually I am writing a upgrade script, and it was failing as it was unable to save the configs.
Thanks anyways to all of you.
