Configuration of Bridging and bvi interface
tyagi.vineet
which IOS version i need, to configure bridging on Catalyst 4506 and catalyst 3560, any link for download? How to configure the same ?
bvsnarayana03
Level 5
Level 5
It should work with your current version of IOS. I dont remember exactly, but it was avail from early 11.x series.
Here is the link for configuration:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca767.html
hope that helps.
pls rate all helpful posts.
Vineet
The configuration of bridging and of IRB which uses the BVI are for IOS based routers. I do not believe that you can do them on your 4506 and 3560 which are switches. The switches inherently support bridging (which they identify as switching - same function but different name) and I believe that they do not support BVI.
Rick
Rick
