Configuration transferring from switch to switch
Shibu1978
Dear All,
What are the ways through which i can copy the entire configuration from one Cisco 2950 switch to another same switch.
Shibu
andrew.prince
Level 10
Level 10
copy, cut and paste
pull the config from a tftp server
HTH>
You may need to copy (vlan.dat) or recreate the VLAN db. You will also need to create SSH keys and any other device specific items.
Hope that helps.
