Configure 3560X switch for iSCSI connectivity
smeek
I haven't worked with infrastructure much lately but planning on replacing a Dell switch used for a small iSCSI SAN with a Cisco 3560x. Switch is sstorage ONLY, network handled through different switches. I believe I want to disable spanning tree and configure trunking for the 4 GB ports connected to the storage array. The switch is providing connectivity to SAN via multiple GB connections and then also multiple GB connections to 3 Vmware hosts.Can you look over the changes I made to config below and let me know if I am on the right track.
I also plan to add a second switch later with the 10GB modules to interconnect for redundancy (but not worried about that part for now). I do not plan on using jumbo frames.
Here are my questions
1) Is the best way to globally disable spanning tree for the switch?
2) Did I trunk the ports correctly below?
3) Should I apply any specific SmartRoles to the 4 SAN NICs (GE1-4) or to host NICs (GE13-20)?
4) Anything additional I should do to handle iSCSI data?
Here is a copy of the config so far with my changes marked in RED.
storage1#wr t
Building configuration...
Current configuration : 1696 bytes
version 12.2
no service pad
hostname storage1
boot-start-marker
boot-end-marker
enable secret 5 BLAHBLAHBLAH.
enable password BLAHBLAHBLAH2
no aaa new-model
system mtu routing 1500
cluster enable storagecluster 0
spanning-tree mode pvst
no spanning-tree vlan 1
vlan internal allocation policy ascending
interface FastEthernet0
ip address x.x.x.x 255.255.255.0
interface GigabitEthernet0/1
description Stonefly ports
switchport mode access
channel-group 5 mode desirable non-silent
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
description host NICs
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
ip http server
ip http secure-server
ip sla enable reaction-alerts
snmp-server community public RO
line con 0
line vty 0 4
password BLAHBLAH3
login
line vty 5 15
password BLAHBLAH3
login
end
smeek
The hosts are running Vmware ESXi 5.x, in case that impacts any feedback.
Were you able to find answers?  I have the 3560X as well and am curious too of the configuration. Two switches are only for iscsi traffic in a vlan connected to dell SAN with two controllers (3 total links from the active san controller is plugged into the iscsi switch--two of the type7 controller ports are plugged into swi1 and the other is in swi2).  The other (4th) port on the type7 san controller is for management--wired to a third switch.
I have the following config snippet. I'm having some performance issues and wondering if anyhting needs adjusting? Is spanning-tree required, and configured correctly, is flowcontrol turned on correctly?  If I run a show int gi0/3 it says flow-control is off even though the NIC has it turned on.  Is portfast required on the switch ports?
version 12.2
no service pad
service password-encryption
service sequence-numbers
no service dhcp
hostname iscsiswitch
boot-start-marker
boot-end-marker
no logging console
aaa group server radius RADIUS
aaa authentication login CONSOLE line
aaa session-id common
system mtu routing 9198
ip domain-name .....
vtp mode off
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree portfast default
spanning-tree portfast bpduguard default
spanning-tree portfast bpdufilter default
port-channel load-balance src-dst-mac
vlan dot1q tag native
vlan 12
name iSCSI
vlan 665
name Management
vlan 99
name UNUSED_PORTS
ip ssh source-interface FastEthernet0
ip ssh version 2
interface Port-channel11
description Uplink to other iscsi switch
switchport access vlan 665
switchport trunk native vlan 665
switchport nonegotiate
ip flow ingress
ip flow egress
flowcontrol receive on
spanning-tree bpdufilter disable
spanning-tree bpduguard disable
description Management Interface
ip flow ingress
ip flow egress
ip address 10.10.x.x 255.255.255
description server 1
switchport access vlan 12
ip flow ingress
ip flow egress
flowcontrol receive desired
description server 2
ip flow ingress
ip flow egress
description  server 3
ip flow ingress
ip flow egress
description Uplink to ToOtherSwitch (Gi1/1)
ip flow ingress
ip flow egress
channel-group 11 mode on
description Uplink to ToOtherSwitch (Gi1/2)
ip flow ingress
ip flow egress
description Uplink to ToOtherSwitch (Gi1/3)
ip flow ingress
ip flow egress
description Uplink to TOOtherSwitch (Gi1/4)
ip flow ingress
ip flow egress
shutdown
shutdown
interface Vlan1
no ip address
shutdown
Thanks for any advice.
rmcgurn
For what it's worth (I know this question has been here for a long time) I've found that using port-channels with iSCSI is not as good as using MPIO setup correctly.  iSCSI isn't too complicated, but certain prerequisites do have to be met in order for you to gain acceptable performance.  A good "non-blocking" switch is crucial.  3560X ought to be fine, 3560G, not so much (oversubscription on the ports on 3560G model).
Another thing to keep in mind is your storage IP configuration.  Please check with your storage vendor for which method is best.  For example, Dell has 2 products, EquaLogic and MD3000 series.  Both use iSCSI, but with EquaLogic, is recommended to have all your NICs use an IP address in same subnet "iSCSI VLAN", and you put your initiator NICs on same subnet as well.  You then should keep this subnet completely isolated from the rest of your network.  For the MD3000 however, different NICs on SAN are supposed to each be in their own individual subnet, such as:
10.1.1.5
10.1.2.5
10.1.3.5
10.1.4.5
Many Unix/Linux based solutions operate this way also using a different Subnet/NIC.  Best thing gain, check with storage vendor for best practices for IP configuration.
Port channels work better for NFS than iSCSI.  Also, disable unicast storm control.
Another thing to do is enable flow-control.  Although the 3560X/3750X will only configure flow-control in "receive", they will not actually send out pause-frames.
Hard code your switch ports and NIC interfaces
Ensure that STP is disabled, at least on iSCSI interfaces.
Beyond that, ensure your cabling is good, if you're using routed storage, meaning different subnets per NIC, then ensure you have as few hops as possible to targets.  Keeping latency low as possible is also crucial.
Hope this helps some.
