11-24-2022 12:00 AM - edited 11-24-2022 12:01 AM
hi,
i'll configure a C9300 switch but the C9300-NM-8X isn't installed yet.
i can see ten gig 1/1/1-8 interfaces are available.
are these reserved for the 8-port module? can i pre-configure these interfaces withoug the said module yet?
9300#sh inv
NAME: "c93xx Stack", DESCR: "c93xx Stack"
PID: C9300-48T , VID: V01 , SN: FOC2xx
NAME: "Switch 1", DESCR: "C9300-48T"
PID: C9300-48T , VID: V01 , SN: FOC22xx
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C1-350WAC , VID: V02 , SN: ART221xx
NAME: "Switch 1 - Power Supply B", DESCR: "Switch 1 - Power Supply B"
Te1/1/1 unassigned YES unset administratively down down
Te1/1/2 unassigned YES unset administratively down down
Te1/1/3 unassigned YES unset administratively down down
Te1/1/4 unassigned YES unset administratively down down
Te1/1/5 unassigned YES unset administratively down down
Te1/1/6 unassigned YES unset administratively down down
Te1/1/7 unassigned YES unset administratively down down
Te1/1/8 unassigned YES unset administratively down down
9300#sh run int Te1/1/1
Building configuration...
Current configuration : 51 bytes
interface TenGigabitEthernet1/1/1
shutdown
end
11-24-2022 12:05 AM
it's not make any difference if you apply the config before or after, but I would advise applying the config after the module is installed.
you will not get any advantage to apply that config before since the module is not present. (rather it crate confusion for other network engineers)
11-24-2022 01:02 AM
hi,
the engineer is just me
so i don't worry about the potential confusion.
can you confirm these ten gig links are "reserved" or meant for the C9300-NM-8X module?
can i pre-configure these ten gig links with trunks and etherchannel?
11-24-2022 02:22 AM
C9300-NM-8X - if you installing, i would suggest to config on interface ten 1/1/1 (not gig ports)
yes you can configure - but as i said no value if there is no interface in place or module in place.
