Configure an IP address for that VLAN interface
tie
Hello everyone,
I am hoping that someone can point in the right direction. I just got my geeky hands on a two 3750G switches and went, "Yuppie no more router on a stick for me, inter vlan routing here I come!!!"
I happily started to move my VLAN's off my good and trusty 2950 on to the 3750G. Now I know that the default gateway for my VLAN's are the SVI interfaces that I built on the 3750. This is where I come into the problem.
According to this URL http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
Everything is good to go up to Step 6. This is where I got stuck untill I saw this this note at the end....
"Note:  This step can be omitted if the  switch reaches the default router through a VLAN. In its place,  configure an IP address for that VLAN interface."
The statement of "...default router through a VLAN." is ture in my case. Which brings me to my question: Can some please give me example of what Cisco means by this. I thought SVI was the "IP address for that VLAN interface."
One thing I should add is every works like a champ if I go back to router on a stick, trying to get this inter vlan routing is proving to be a bit tougher.
If it helps here is my network layout, switch, and router configs.
VLAN 10 management
VLAN 70 is a /28 that is framed to me by my ISP. Port-channel1.70 has to 70.57.155.254
VLAN 192 is a /24 that is all things DHCP and WiFi
VLAN 193 is a /24 that is all things static IP's like servers, WiFi access points, basicly anything that supports VLAN 192
-- Switch config --
version 12.2
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
no service dhcp
hostname Stack
enable secret 5 <PASSWORD>
enable password 7 <PASSWORD>
no aaa new-model
switch 1 provision ws-c3750g-24t
switch 2 provision ws-c3750g-24t
system mtu routing 1500
ip subnet-zero
ip routing
no ip gratuitous-arps
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Loopback0
ip address 10.0.1.1 255.255.255.0
interface Port-channel1
description To 2901
switchport mode trunk
interface Port-channel2
switchport access vlan 70
switchport mode access
interface Port-channel3
interface Port-channel4
interface Port-channel5
interface Port-channel6
switchport access vlan 192
interface Port-channel7
switchport access vlan 193
interface GigabitEthernet1/0/1
channel-protocol lacp
channel-group 2 mode active
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
channel-group 4 mode active
interface GigabitEthernet1/0/4
channel-group 5 mode active
interface GigabitEthernet1/0/5
no switchport
no ip address
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
description To 2901
channel-group 1 mode on
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
channel-group 7 mode active
interface GigabitEthernet1/0/24
channel-group 6 mode active
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 10.0.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan70
ip address 70.57.155.241 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan192
ip address 192.168.3.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan193
ip address 192.168.5.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip default-gateway 10.0.0.254
ip classless
no ip http server
no ip http secure-server
no cdp run
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
scheduler process-watchdog reload
end
-- Router Config --
version 15.3
service nagle
no service pad
no service dhcp
hostname 2901
boot-start-marker
boot system flash1 c2900-universalk9-mz.SPA.153-1.T.bin
boot-end-marker
enable secret 4 <PASSWORD>
no aaa new-model
clock timezone CST -6 0
clock summer-time CST recurring
ip cef
ipv6 spd queue min-threshold 62
ipv6 spd queue max-threshold 63
ipv6 multicast rpf use-bgp
no ipv6 cef
vpdn enable
vpdn-group 1
license udi pid CISCO2901/K9 sn FTX1539817B
controller VDSL 0/0/0
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Loopback0
ip address 10.0.1.254 255.255.255.0
interface Null0
no ip unreachables
ip address 172.31.1.254 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip tcp adjust-mss 1452
hold-queue 150 in
interface Port-channel1.10
encapsulation dot1Q 10 native
ip address 10.0.0.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface Port-channel1.70
encapsulation dot1Q 70
ip address 70.57.155.254 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
interface Port-channel1.192
encapsulation dot1Q 192
ip address 192.168.3.254 255.255.255.0
ip helper-address 192.168.5.5
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly in
interface Port-channel1.193
encapsulation dot1Q 193
ip address 192.168.5.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
channel-group 1
no cdp enable
no mop enabled
interface GigabitEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
channel-group 1
no cdp enable
no mop enabled
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
shutdown
no atm ilmi-keepalive
ntp disable
no snmp trap link-status
hold-queue 224 in
interface Ethernet0/0/0
no ip address
interface Ethernet0/0/0.201
encapsulation dot1Q 201
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer0
mtu 1492
ip unnumbered Port-channel1.70
ip access-group from_internet in
ip access-group to_internet out
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ntp disable
ppp authentication chap pap callin
ppp chap hostname <USERNAME>
ppp chap password 7 <PASSWORD>
ppp pap sent-username <USERNAME> password 7 <PASSWORD>
ppp ipcp route default
no cdp enable
no ip forward-protocol nd
no ip http server
ip nat inside source list NAT interface Port-channel1.70 overload
ip access-list extended NAT
permit ip 192.168.3.0 0.0.0.255 any
permit ip 192.168.5.0 0.0.0.255 any
deny   ip any any
ip access-list extended from_internet
evaluate reflexive-temporary-list
deny   tcp any any fragments
deny   udp any any fragments
deny   icmp any any fragments
deny   ip any any fragments
deny   udp any any eq netbios-ns
deny   udp any any eq netbios-dgm
deny   udp any any eq netbios-ss
deny   ip 0.0.0.0 0.255.255.255 any
deny   ip 10.0.0.0 0.255.255.255 any
deny   ip 127.0.0.0 0.255.255.255 any
deny   ip 169.254.0.0 0.0.255.255 any
deny   ip 172.16.0.0 0.15.255.255 any
deny   ip 192.168.0.0 0.0.255.255 any
deny   ip 224.0.0.0 15.255.255.255 any
deny   ip any 0.0.0.0 0.255.255.255
deny   ip any 10.0.0.0 0.255.255.255
deny   ip any 127.0.0.0 0.255.255.255
deny   ip any 169.254.0.0 0.0.255.255
deny   ip any 172.16.0.0 0.15.255.255
deny   ip any 192.168.0.0 0.0.255.255
deny   ip any 224.0.0.0 15.255.255.255
deny   ip host 0.0.0.0 any
permit tcp any host 70.57.155.242 eq 22
permit udp any host 70.57.155.242 eq domain
permit udp any host 70.57.155.242 eq ntp
permit tcp any host 70.57.155.242 eq smtp
permit tcp any host 70.57.155.242 eq 3128
permit tcp any host 70.57.155.234 gt 1024
permit udp any host 70.57.155.234 gt 1024
permit tcp any host 70.57.155.245 eq www
permit tcp any host 70.57.155.245 eq 443
permit udp any host 70.57.155.243 eq domain
permit udp any host 70.57.155.243 eq ntp
permit tcp any host 70.57.155.243 eq www
permit tcp any host 70.57.155.243 eq smtp
permit tcp any host 70.57.155.243 eq 995
permit tcp any host 70.57.155.243 eq 443
permit tcp any host 70.57.155.243 eq 7071
permit tcp any host 70.57.155.243 eq pop3
permit tcp any host 70.57.155.243 eq 143
permit tcp any host 70.57.155.243 eq 465
permit tcp any host 70.57.155.243 eq 993
permit icmp any any administratively-prohibited
permit icmp any any echo-reply
permit icmp any any packet-too-big
permit icmp any any time-exceeded
permit icmp any any traceroute
permit icmp any any unreachable
deny   ip any any
ip access-list extended to_internet
permit ip 70.57.155.240 0.0.0.15 any reflect reflexive-temporary-list timeout 300
deny   ip any any
dialer-list 1 protocol ip permit
no cdp run
access-list 1 permit any
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
ntp server 70.57.xxx.yyy
ntp server 70.57.xxx,yyy
end
5 Replies 5
John Blakley
I believe what they're stating is that you don't need to configure a L3 interface if you're going to be using a L3 svi in its place. In other words, if your router had an address of 192.168.1.1/30 and it was connected to port 1 on the switch, you could configure port 1 on the switch like:
int fa0/1
no switchport
ip address 192.168.1.2 255.255.255.252
That would be sufficient to get routing working between the switch and router. But since you're using L3 svi's, you can skip that step.
A L3 svi is the:
int vlan10
ip address 10.10.10.1 255.255.255.0
The gateway for the host would be vlan 10's IP. If your router was also in vlan 10, then your default route would point to the router's interface that connects to the switch.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
glen.grant
  Whats not working, unclear from your posting.
I agree with John that the assumption in the article is that the connection from switch to router was in a subnet that was different from any of the VLANs on the switch. So they did no switchport and treated the switch interface as a layer 3 interface. In the case of the original poster the VLANs on the switch do have corresponding subnets on the router. And so there is no need to configure no switchport.
One thing I notice is that the original poster did not do step 7 in the article which is to configure a default route. If you are going to do the routing on the switch then a default route is important.
It is not clear in the original post whether the end stations are being configured to have their default gateway point to an address on the switch (which is step 8 in the article) or whether the end stations still have their default gateway pointing to the router. If the end stations do have their default gateway pointing to the switch then the default route is important and inter vlan routing is really being done. If the end stations still point to the router as their default gateway then the default route on the switch is not important - and inter vlan routing is really not being done on the switch.
Rick
Rick
tie
Thanks everyone.
But in the end I gave up, for now.
Mr. Blakley thank you sir, Your post was very helpful, however I don't think I have all the hardware I need to make this happen. I clearly don't have the "know how".  Time to order a book me thinks.
glen.grant, My fault, sorry if I was not clear. It was a question of understanding and looking of an example of the "NOTE: ...." in step 6 in the URL in my first post. Not a matter of what is not working. Mr. Blakley example helped in that reguard.
Mr. Burts, you are right. I never did make it to step 7, as in step 6 was talking about "configure an IP address for that VLAN interface", that is what I could not get my head around.
Let me explain (or try to) what's is/was going on in my old man head.
History:
I have 3 VLANS, and 1 Management VLAN. My ISP "upgraded" the area I live in from ADSL to VDSL. This obsoleted my Cisco 2811. So I jumped to a Cisco 2901. I also choose to upgrade my 2950 switch to two 3750G's with Stackwise and build LACP port-channels into each server, one server NIC in to one switch, the other server NIC in to the second switch.
Problem:
In "old" setup the Cisco 2811 was trunked to a 2950, router on a stick. Now I know that SVI interfaces become the new default gateway for any device that assigned to that VLAN via switchport access vlan . Easy and it worked great. If I was on a host in any VLAN, and ping'ed, SSH, https, whatever to a host in the other two all worked great. This where things fell apart, the problem was getting traffic to and from 3750G stack to the 2901 and keeping their VLAN IDs (I hope I said that right) as the router is the default gateway to the internet for all three VLANs.
VLAN 70 is /28 of internet routed IP.
VLAN192 and VLAN193 are both nat'ed.
It was at that point I found in the URL above
"Note: This step can be omitted if the switch reaches the default router through a VLAN." I thought Hey that's me, I think....Ok how do I do it? No example of this is listed. I will ask.
Things that I have tried:
Static routes on the 3750 based on what Mr. Blakley if I understood it.
On the 3750G (Yes, ip routing is on)
ip route 70.57.155.240 255.255.255.240 70.57.155.254
ip route 192.168.3.0 255.255.255.0 192.168.3.254
ip route 192.168.5.0 255.255.255.0 192.168.5.254
Where all of the .254 addresses are IP addresses on the Cisco 2901 however they are dot1q encapsulated.
No go...
OSPF/EIGRP (Both router and switch)
router 111
  network 70.57.155.240 255.255.255.240 area 0
  network 192.168.0.0 255.255.0.0 area 0
No dice. And it was right over my head. Learned a good amount but did not help.
Oddly in a last act of desperation...this kinda worked...
ip route 0.0.0.0 0.0.0.0 70.57.155.254
ip route 0.0.0.0 0.0.0.0 192.168.3.254
ip route 0.0.0.0 0.0.0.0 192.168.5.254
The problem with it was is was unreliable and painfully slow. To be point blank I don't think it was working right.
So as Mom and Dad always put it "If it ain't broke don't fix it". Router on a stick it is. Yeah, I never listened to Mom and Dad aways.
As I attempted to explain in my previous post, the major issue in your config of the 3750 was the lack of default route for the switch.  As long as the end stations continue to have their default gateway using the addresses on the router then the network worked. And your 3750 would operate mostly as a layer 2 switch. You may have deployed a layer 3 switch (and enabled routing on it) but it was operating mostly as a layer 2 switch and forwarding traffic to the router for routing.
If you really want to get into inter vlan routing then the hosts on the vlans need to have their default gateway as addresses on the 3750. And if you are going to do this then I would suggest that you change the connectivity between the 3750 and the router from a trunk (where the vlans have subinterfaces on the router that are dot1q encapsulated to a routed subnet. And the 3750 must have a default route pointing to the router.
Rick
Rick
