Configure SSH for 4900M
olsonkyle12
I'm interested in a per command line example to configure SSH on a Cisco 4900M.  There is no TACACs or logging server for SSH on this switch, everything is local to the switch.
2 Accepted Solutions
Reza Sharifi
In order to run SSH you need an IOS image with letter K and number 9 in it
see example
S49MIPBK9-12246SG
vmiller
Level 7
Level 7
To add to Rezas answer (he types faster than me), read the following.
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml
Its a pretty good how to
6 Replies 6
Reza Sharifi
see example
S49MIPBK9-12246SG
Okay, so I need to download a new image onto the 4900M.  Is there a good article on how to do this with a TFTP server?
vmiller
Level 7
Level 7
Installed a crypto IOS and was able to configure Crypto command, but when I try and SSH to the device, the host activley refuses
connection.  Below is my config, please let me know if you see anything missing:
show run
Building configuration...
Current configuration : 3076 bytes
version 15.0
no service pad
service password-encryption
service compress-config
hostname NGS-4900B-RCK5
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$WPDS$KyTSKCBFdTpPfdrZo.spI.
username admin password 7 12381F161E0E5C176B
aaa new-model
--More--                           !
aaa session-id common
ip subnet-zero
ip domain-name Grid.local
ip vrf mgmtVrf
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
--More--                           !
vlan 100
name Primary_Server_Subnet
vlan 103
name Management_Vlan
vlan 104
name Replication_Network
ip ssh authentication-retries 5
ip ssh version 1
interface FastEthernet1
ip vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface TenGigabitEthernet1/1
switchport trunk allowed vlan 100-104
switchport mode trunk
--More--                           !
interface TenGigabitEthernet1/2
interface TenGigabitEthernet1/3
interface TenGigabitEthernet1/4
interface TenGigabitEthernet1/5
interface TenGigabitEthernet1/6
interface TenGigabitEthernet1/7
interface TenGigabitEthernet1/8
--More--                           interface GigabitEthernet3/1
interface GigabitEthernet3/2
interface GigabitEthernet3/3
interface GigabitEthernet3/4
interface GigabitEthernet3/5
interface GigabitEthernet3/6
interface GigabitEthernet3/7
interface GigabitEthernet3/8
interface GigabitEthernet3/9
interface GigabitEthernet3/10
switchport access vlan 100
interface GigabitEthernet3/11
--More--                           interface GigabitEthernet3/12
interface GigabitEthernet3/13
interface GigabitEthernet3/14
interface GigabitEthernet3/15
interface GigabitEthernet3/16
interface GigabitEthernet3/17
interface GigabitEthernet3/18
interface GigabitEthernet3/19
interface GigabitEthernet3/20
interface Vlan1
no ip address
shutdown
interface Vlan100
--More--                            description Primary Server Network
ip address 10.234.240.3 255.255.255.0
ip helper-address 10.234.240.62
standby 1 ip 10.234.240.1
standby 1 timers 1 4
standby 1 priority 104
standby 1 preempt
interface Vlan103
description Management Vlan
ip address 10.234.241.3 255.255.255.0
standby 1 ip 10.234.241.1
standby 1 preempt
interface Vlan104
description Replication Network
ip address 10.234.237.131 255.255.255.192
standby 1 ip 10.234.237.129
standby 1 preempt
--More--                           !
router eigrp 100
network 10.234.237.128 0.0.0.63
network 10.234.240.0 0.0.0.255
network 10.234.241.0 0.0.0.255
eigrp stub connected summary
ip route 0.0.0.0 0.0.0.0 129.33.202.197
ip http server
no ip http secure-server
line con 0
stopbits 1
line vty 0 4
password 7 052A1C0E2D491E1A58
transport input telnet
end
NGS-4900B-RCK5#
check the vty lines (assuming you are telnetting) and add modify the transport input to include ssh
