Configure static routing fail-over to backup
getaway51
Level 2
Level 2
I have 2 WAN links. Therefore I need to enable traffic to go to WAN1. WAN2 is just a backup.
If I just use metric, will the backup route@WAN2 works if main route fails? or need to configure "track"?
ip route 202.188.7.12 255.255.255.255 10.1.1.1---main route@WAN1
ip route 202.188.7.12 255.255.255.255 10.1.1.2 10-----backup route@WAN2
ip route 202.188.7.12 255.255.255.255 10.1.1.1?
<1-255> Distance metric for this route
multicast multicast route
name Specify name of the next hop
permanent permanent route
tag Set tag for this route
track Install route depending on tracked item
10 Replies 10
Hello
Yes would suggest you use a conditional static route which would assist in failover to the less preferred static route if the primary path became unavailable.
Kind Regards
Paul
Deepak Kumar
Yes, it will be work. It will select the main route WAN1 and if it is down then it will go with the backup route.
But if you want a true backup line as anything happens in the between at ISP or after 10.1.1.1 then go with the track.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
If the main route next-hop is down, will it still use the main route? since there is no track, does it still works?
When will the switch will use the 2nd route, based on what?
What is the best config for active-backup failover?
I saw many switches configured route without ip sla.
Can i said tht the below main static route will still run even if 10.1.1.1 is down, since there is no ip sla?
Thanks for advice.
Hello @getaway51 ,
your understanding is correct in the worst case the main route will be removed only when the ARP entry for 10.1.1.1 will expire on the ARP table ( up to 4 hours with default settings !!!)
This can happen if :
a) you are using an SVI interface that has other links in addition to the WAN link (the so called autostate) the SVI will stay up even if the WAN link fails
b) it can happen even if you are using a dedicated SVI or a routed port for the WAN link if the fault does not cause the physical interface to go down ( remote fault with provider not using ethernet OAM to tear down the local port)
For all these reasons the use of IP SLA and tracking is recommended to be sure that fallback to secondary route will happen in a timely manner.
Edit:
the next-hop of the secondary route should be in a different IP subnet something like 10.1.2.1 (if using /24) or 10.1.1.5 ( if using /30 subnet)
Hope to help
Giuseppe
May i know why "the next-hop of the secondary route should be in a different IP subnet"?
Is there any difference than putting all in same subnet?
Hello
I attached an example of a condictional static route with ipsla tracking which should provide you with what you are requesting - Have you tried this?
Kind Regards
Paul
I wanted to use both as active-active.Any one down, the switch will remove the route immediately.
conf t
ip sla 1
icmp-echo 10.1.1.1 source-ip 10.1.1.5
threshold 30=====>to failover if 30 seconds down
frequency 1
ip sla schedule 1 life forever start-time now
track 1 rtr 1 reachability
ip sla 2
icmp-echo 10.1.1.2 source-ip 10.1.1.5
frequency 1
track 2 rtr 2 reachability
ip route 202.188.7.12 255.255.255.255 10.1.1.1 track 1
ip route 202.188.7.12 255.255.255.255 10.1.1.2 track 2
Hello @getaway51 ,
you have described your scenario as having two WAN links WAN1 and WAN2 and I have supposed those two links are two routed links as a result of this they should be in different IP subnets.
If your WAN1 and WAN2 links are OSI layer2 links you can have a single IP subnet that covers both , but I would say that using different IP subnets is to be preferred as in this way you can have two different SVI or routed interface and if WAN1 fails on local side it triggers backup route.
If you want to use a single IP subnet on WAN1, WAN2 so that both next-hops are in the same IP subnet you need to use IP SLAs and tracking to be able to fallback to secondary path in a timely manner.
Hope to help
Giuseppe
You mean if configured routing next-hop which is on 2 different subnets like vlan2 and vlan3, failover will trigger immediately, Just like "ip sla track"?
Any reason or do i get it wrong?
ip route 0.0.0.0 0.0.0.0 10.1.1.1---main route@WAN1
ip route 0.0.0.0 0.0.0.0 10.1.1.2 10-----backup route@WAN2
ip route 150.20.1.3 255.255.255.255 10.1.1.1----3rd dedicated routing
If 10.1.1.1 is down, the switch will not remove any routes above till
expire on the ARP table ( up to 4 hours with default settings !!!) ??
