Configure switch for Nutanix??
CiscoBrownBelt
Level 6
Level 6
Anyone have a baseline or good info you can give me to configure some 4510 or 3548 switches for Nutanix (or software defined network)? I understand that ISIS and BGP is used within the Lan for Nutanix.
Reza Sharifi
BGP and ISIS will be deployed on the SDN (Nutanix) or the 4500?
On the 4500. To my understanding, since Nutanix will be running its own routing configs and all, therefor BGP, ISIS, MACSEC, VXLAN will all be used. I believe we will need to run the routing protocols on a router connecting to the 4500s.
Not all Cisco devices support all these features like VXLAN. So, if you are the one buying the product, you want to make these features are in fact supported and you have the right license.
Yes. My question is, given the servers are for Nutanix, will everything that I stated need to be configured? I am basically looking for some type of baseline or guidance to configure LAN infrastructure for an SDN environment.
