DAI IP arp inspection
tedauction
Hello, I cannot run the full commands to implement DAI ARP inspection on my WS-C2960-48PST-L   12.2(46)SE switch.
Is this because the IOS does not support it ?
I thought it would be supported as it is currently running DHCP snooping.
Thanks for any help.
ulineosan
tedauction,
Are you using this guide? Exactly which commands(s) are not accepted by the switch?
