Configure WOL for Catalyst 2960-X
mt.letterbox
Hi all,
Need your kind advice on setting up Wake On LAN (WOL) for my DELL machines. Currently I am trying to setup WOL for my servers and workstations in my server rack. Configuration for the servers and machines are completed and tested to be working on an unmanaged SOHO switch. However, when i installed and setup CISCO Catalyst 2960-X switch, I am unable to WOL for my servers and workstations.
Question:
(1) Does Catalyst 2960-X switch supports WOL?
(2) Does Catalyst 2960-X switch need to configure settings to support WOL?
Thank you.
Mark
5 Replies 5
Mark Malone
wol needs to be setup it doesn't just run on Cisco devices
You need to set it up on the layer 3 device your routers or is the 2960x acting as L3 ? I know some newer xr  and x models have L3 capabilities , it should be setup where the inter vlan routing is done
Wol gets setup like dhcp helper under a layer 3 vlan with directed broadcast setup
This doc shows an example for L3 3750 , would be same concept for any L3 device set it at the vlan
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/91672-catl3-wol-vlans.html
Hi Mark,
Thanks for the advice.
Can I check whether without a layer 3 switch, can WOL be configured using a layer 2 switch?  All the machines are connected to 1 VLAN for this setup, thus there is no need for interVLAN routing.
Hope to hear from you soon.
Thanks!
you shouldnt require inetervlan routing but you will require an SVI interface , can you not apply it to vlan 1 interface if thats all thats running on the switch
its ip directed broadcast so there needs to be a layer 3 interface
2960X does not support the command "ip forward-protocol", so you cannot add the desired UDP-port to forwarding
First of all do you server nics support WOL and are they configured to do so?
Now as this switch is only a host switch then you need a rtr or l3 device to send directed broadcasts to this switch and the servers.
You do this on the rtr/l3 switch
ip forward protocol udp echo
access-list 100 permit udp host <dhcp server ip> host <server1> eq echo
access-list 100 permit udp host <dhcp server ip> host <server2> eq echo
int vlan xx
description server vlan
ip helper-address x.x.x. < relay for dhcp server (if applicable)
ip directed broadcast 100
Kind Regards
Paul
