Configuring 2 Vlans on 2 switches and 1 router - please help.
SLikovs
Hi there.
Im trying to set up 2 VLANS on a topology, that consists of 4 PCs, 2 Switches and 1 Router.
Task is , that 2 PCs that go to 1 switch run on separate Vlans, VLAN 10 and VLAN 20, and than on another Switch situation is the same.
I have configured encapsulation on router for desired subinterfaces, ports from switch to router are set to trunk. Ports on switch are assigned to relevant VLAN. Still nothing is working.
Could anyone advice the right way to go?
Hello
You had quite a few mis-configurations, please review the working PT file
Kind Regards
Paul
Hello
The two switches interface require to be trunks connecting to the rtr, and you need to create the l2 vlan on each switch.
How are the pc obtaining their ip addressing, dhcp or statically assigned?
Post the PT file if you like.
Kind Regards
Paul
SLikovs
Hi Paul
Trunks done, Vlans added to database.
All IPs are statically assigned.
I think I got configuration wrong somewhere, please see PT file.
There are 2 versions of the same network, I was trying different methods to achieve the outcome - none seem to work, as I cant get hosts talking to each other within the assigned VLAN.
Any suggestions on how to fix it would be great - thanks in advance for  your help.
Hello
Kind Regards
Paul
Hi Paul
Thanks a lot for your help, will send you a private message.
