Catalyst 2960L-8PS - Switch Fails to Verify MCU Firmware
Mike-
Hi, I restarted Catalyst 2960L-8PS switch today, but the switch never came back up. I consoled in and found that the switch was constantly restarting. The error messages are:
1.) Verifying MCU firmware... Fail
2.) MCU firmware Upgrade Fail - failed to get MCU data
3.) Invalid parameter block. Using Mac address of 0:0:0:0:0:0
4.) POST: ACT2 Authentication: End, Status Failed driver class subsystem initialization failed.
5.) Cloud not get Msemi to gracefully enter recovery state.
6.) nand bad command - shows bad blocks
Here are the screenshots
Is there a way to recover the switch?
          - The device has a fatal hardware problem and needs to be RMA-ed
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
5 Replies 5
Mark Elsen
                    - Which options are available under that nand command = nand ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Only nand bad shows as available command.
nand ?
nand bad
nand ?nand ?
     - Try fsck flash:
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Received unknown command
"Unknown cmd: fsck"
Switch is in a limited ROMMON.
switch: ?switch: ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
