Configuring Cisco 1811W
mrmacking
I have been trying to configure a Cisco 1811W with lan, dhcp and wifi for about a week now.  What am I missing here?  Really need some help.
!This is the show startup-config output of the router: show startup-config
Using 4320 out of 196600 bytes
! Last configuration change at 21:40:30 NewYork Wed Oct 20 2010 by timmy
! NVRAM config last updated at 21:47:18 NewYork Wed Oct 20 2010 by timmy
version 12.4
hostname yourname
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 51200 warnings
no aaa new-model
clock timezone NewYork -5
clock summer-time NewYork date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-1318348147
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1318348147
revocation-check none
rsakeypair TP-self-signed-1318348147
crypto pki certificate chain TP-self-signed-1318348147
certificate self-signed 01 nvram:IOS-Self-Sig#5.cer
dot11 syslog
dot11 vlan-name Wireless vlan 2
dot11 ssid FW_WIFI1
vlan 2
authentication open
wpa-psk ascii 0 HOPEITWORKS
dot11 ssid FW_WIFI2
vlan 2
authentication open
ip source-route
ip dhcp excluded-address 10.10.10.76 10.10.10.254
ip dhcp pool sdm-pool
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   domain-name HOPEITWORKS.com
   dns-server 4.2.2.1 4.2.2.2
   lease 0 9
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
username timmy privilege 15 secret 5 $1$rKRmXCXCXCXCXCXCXCX/dFnkEk.
archive
log config
  hidekeys
interface Dot11Radio0
no ip address
ssid FW_WIFI1
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.2
encapsulation dot1Q 2 native
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio1
no ip address
ssid FW_WIFI2
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio1.2
no cdp enable
bridge-group 2
interface FastEthernet0
no ip address
duplex auto
speed auto
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1452
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
line con 0
login local
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
end
ililim
Hi mrmacking,
Are you trying to configure this 1811 as the gateway for your LAN and to share a common subnet with your internal LAN interface and dot11Radio?
You should create a bridge group that consists of your ethernet interface and your dot11radios in this case.
You need to activate the bridge protocol (commonly ieee).
Enable bridge irb for routing in this BVI and apply the subnet ip address on this BVI from vlan 1.
Also remove the vlan 1 as it won't be needed.
Here is a link for additional information: http://www.cisco.com/en/US/docs/switches/lan/catalyst4840g/12.0_11.5_wx5_18/configuration/guide/4840br.pdf
Ian
