CONFIGURING CISCO 891 ISR
Beneto
Hello there, i hope someone can help me. I have a Cisco 891 ISR that im trying to configure, im quite new with CISCO but so far i was able to get the LTE module to connect and the router has external connectivity. I created a few DHCP Pools as per config bellow, but im unable to ping either the gateway or any other address in the internet, there is defenitely something wrong with the setup. Can someone shed some light and put me in the right direction please.
ip dhcp pool Building Management
!Switching, Branch Router
ip dhcp pool CORP
network 192.168.48.0 255.255.255.224
default-router 192.168.48.254
dns-server 192.168.1.5 192.168.1.6 8.8.8.8
domain-name xxxxxxxx.local
lease 8
ip dhcp pool BUILDING MANAGEMENT
network 192.168.48.96 255.255.255.224
domain-name xxxxx.local
lease 8
ip dhcp pool MANAGEMENT
network 192.168.48.128 255.255.255.224
lease 8
ip dhcp pool PRINTERS
network 192.168.48.64 255.255.255.224
lease 8
ip dhcp pool test
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
lease 8
no ip domain lookup
ip domain name xxxxx.local
ip name-server 192.168.1.5
ip inspect WAAS flush-timeout 10
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid C897VAG-LTE-GA-K9 sn FCZ202590LY
controller VDSL 0
controller Cellular 0
lte failovertimer 1
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
interface ATM0
no ip address
no atm ilmi-keepalive
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
load-interval 30
dialer in-band
dialer idle-timeout 0
dialer string lte
dialer-group 1
pulse-time 1
interface Cellular1
encapsulation slip
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
switchport access vlan 10
no ip address
interface GigabitEthernet1
no ip address
spanning-tree portfast
interface GigabitEthernet2
switchport access vlan 20
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
switchport access vlan 40
no ip address
interface GigabitEthernet5
switchport access vlan 50
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat outside
interface Vlan2
ip address 10.10.1.1 255.255.255.0
interface Vlan10
ip address 192.168.48.254 255.255.255.224
ip nat outside
interface Vlan20
ip address 192.168.48.65 255.255.255.224
ip nat outside
interface Vlan40
ip address 192.168.48.129 255.255.255.224
ip nat outside
interface Vlan50
ip address 192.168.48.97 255.255.255.224
ip nat outside
ip forward-protocol nd
no ip http server
ip http secure-server
ip nat inside source list 1 interface GigabitEthernet1 overload
ip nat inside source list 2 interface Cellular0 overload
ip nat inside source list NAT interface GigabitEthernet1 overload
ip nat outside source list 2 interface Cellular1
ip nat outside source list NAT interface GigabitEthernet1
ip route 0.0.0.0 0.0.0.0 Cellular0
ip route 192.168.1.0 255.255.255.0 Cellular0
ip route 192.168.48.0 255.255.255.0 Cellular0
ip route 0.0.0.0 0.0.0.0 dhcp
ip access-list extended NAT
permit ip 192.168.48.0 0.0.0.255 any
ip sla 1
icmp-echo 8.8.8.8
ip sla schedule 1 start-time after 00:05:00
dialer-list 1 protocol ip permit
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
11 Replies 11
@Beneto
 For start, change the NAT below to "ip nat inside "
In all vlans
interface Vlan1
ip nat outside
interface Vlan2
interface Vlan10
ip nat outside
interface Vlan20
ip nat outside
interface Vlan40
ip nat outside
interface Vlan50
ip nat outside
You are doing NAT overload on the interface GigabitEthernet1. what do you have connected to this interface? It is another internet gateway?
You are doing NAT overload with Access List 2, I dont see Access List 2 anywhere.
Obrigado Flavio
I dont have an ACL2 this was probably a typo, i have removed it not, i end up with only ip nat inside source list NAT interface Cellular0 overload "cellular0" is my LTE modem and for my NAT ACL i have permit ip 192.168.48.0  0.0.0.255 any and changed to IP Nat inside on the VLANS
I still have no outside access, and more weird is i cannot pping the GW 192.168.48.254
Can I see the whole show running-config again?
One more question, 192.168.48.254 is not vlan 10 on your router?
interface Vlan10
@Beneto
 configuration looks much better.
Site to site VPN with DHCP is complicate. The problem is not on this router but in the other end. If your router change the IP address, the other end need to know.
Devaa
Hi @Beneto
network in Corp DHCP pool is wrong, which is not present in any of your vlan. Also, default-router is same in all the pools, which is incorrect. You should update the default-router as the appropriate IP configured in that vlan interface.
! For VLAN 10, I believe
ip dhcp pool CORP
 no network 192.168.48.0 255.255.255.224
 network 192.168.48.224 255.255.255.224
! For VLAN 50
 no default-router 192.168.48.254
 default-router 192.168.48.97
! For VLAN 40
 default-router 192.168.48.129
! For VLAN 20
 default-router 192.168.48.65
Update your DHCP pools as above and check if the devices get IP and gateway is reachable or not. Also check internet.
If gw is reachable and if internet don't work still, share output of below cmd
sh runn | i route|nat|access
Hi Devaa
It does works i can now ping the GW on respective DHCP pools, i guess i had the mask outside of the range?
Do you happen to know how can i go about configuring an IPSEC vpn to a fortigate device using this Router with the downside of using a dynamic IP address over a cellular wan ? Any guidance or documentation would be appreciated
Devaa
You had network id in Corp DHCP pool wrong. Also, the default-gateway was wrong on all other pools.
To configure IPSec VPN between Router and Firewall, you should Public IP at both ends or at least in one end.
You can refer the below config for Site to Site IPSEC tunnel in router side.
conf t
! Feel free to change any attributes as per your requirement
 crypto isakmp policy 1
  hash sha
  auth pre-share
  group 5
  lifetime 7200
  encryption aes 256
  exit
 crypto isakmp key 0 <password> address <firewall-public-ip>
! Create transform set same as in firewall
 crypto ipsec transform-set TSET1 esp-aes 256 esp-sha-hmac
 crypto ipsec security-association lifetime seconds 7200
! Match Interesting Traffic as per your need
ip access-list extended IPSEC_ACL
 permit ip 192.168.48.0 0.0.0.255 192.168.0.0 0.0.255.255
crypto map CMAP1 10 ipsec-isakmp
 match address IPSEC_ACL
 set peer <firewall-public-ip>
 set transform-set TSET1
! LAN to LAN IPSEC
interface <outgoing-interface>
 crypto map CMAP1
Config will defer if you need remote access VPN. Check if the below link helps for Fortinet side.
https://docs.fortinet.com/document/fortigate/6.0.0/cookbook/783623/configuring-ipsec-vpn-on-hq
Manny thanks Devaa, I will give it a go i think the main challenge poses with the dynamic IP address. I will look at the possibility of having the tunnel on demand initiated from the Cisco side perhaps .
I managed to get the IPSEC tunnel up using the configuration bellow, the issue is i can only get the tunnel up if i use the ACL with "any" in the access list, if i revert to 192.168.48.0 0.0.0.255 192.168.0.0 0.0.255.255 the tunnel doesnt form, also with the any in place i loose internet access at both ends and cant ping anything. There is eventually a misconfiguration here that i havent been able to spot, any chances of putting me in the right direction ?
Interface: Cellular0
Profile: profile-tickets
Session status: UP-ACTIVE
Peer: 10.176.19.199 port 500
  Session ID: 1
  IKEv2 SA: local 10.70.180.156/500 remote 10.176.19.199/500 Active
  IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0
        Active SAs: 2, origin: crypto map
        Active SAs: 0, origin: crypto map
crypto ikev2 proposal proposal-tickets
 encryption aes-cbc-256
 integrity sha256
 group 14
crypto ikev2 policy policy-tickets
crypto ikev2 keyring keyring-tickets
 peer tickets
  address 10.176.19.199
  pre-shared-key local xxxxxx
  pre-shared-key remote xxxxxx
crypto ikev2 profile profile-tickets
 match identity remote address 10.176.19.199 255.255.255.255
 identity local address 10.70.180.156
 authentication remote pre-share
 authentication local pre-share
 keyring local keyring-tickets
controller VDSL 0
 lte failovertimer 1
crypto ipsec transform-set trans-tickets esp-aes 256 esp-sha256-hmac
 mode tunnel
crypto map map-tickets 10 ipsec-isakmp
 set peer 10.176.19.199
 set transform-set trans-tickets
 set ikev2-profile profile-tickets
 match address acl-tickets
interface ATM0
 no ip address
 ip nat inside
interface Cellular0
 ip nat outside
 encapsulation slip
 load-interval 30
 dialer in-band
 dialer string lte
 dialer-group 1
 pulse-time 1
interface Cellular1
 encapsulation slip
interface Ethernet0
 no ip address
 shutdown
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 shutdown
 duplex auto
 speed auto
interface Vlan1
interface Vlan2
interface Vlan10
 ip address 192.168.48.1 255.255.255.224
 ip nat inside
interface Vlan20
 ip nat inside
interface Vlan40
 ip nat inside
interface Vlan50
 ip nat inside
no ip http server
ip nat inside source list 1 interface Cellular0 overload
ip access-list extended acl-tickets
ip sla 1
 icmp-echo 8.8.8.8
access-list 1 permit 192.168.48.0 0.0.0.255
Devaa
ACL should match your interesting traffic. permit ip any any will try to tunnel your internet traffic as well. Is that what you need?
Draft ACL based on your need. The Private destination IPs that has to be accessed via tunnel should be in ACL. Leave rest all for your internet to work.
Also, you use peer IPs as private IPs. Is that expected? Are you using any VPN service from ISP? FYI, Some ISPs may block IPSEC traffic in some countries.
You can use PBR as well, if required.
The IP is CGNAT provided by my mobile SIM provider  I'm able to VPN between devices in the same CGNAT range but traffic doesn't flow. Will need to request a true not natted public IP to have this solved. Manny thanks for your help Devaa
