enable mode access issue in TACACS
Shan Ramu
I am using Cisco secure ACS as TACACS server for Dell switch. I am able to login without any issues. However when I get into enable to mode and run any command, not getting any output. Getting output when not using TACACS server. There is no authentication method for enable mode in Dell.
Is there anything I need to do in Cisco secure ACS ?
Hello
Ive not touched a dell for some time, but their cli was very similar to ciscos and in cisco to allow access into privilege exec mode via the enable password see example below:
enable algorithm-type sha256 secret xxx
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization console
Kind Regards
Paul
Sorry, I don't see 'enable' or 'exec'. see only login option. I am using dell OS10 switch, if this helps.
