Configuring DHCP Snooping
CC Estelle
Hi All,
I want to enable DHCP snooping on my access layer switches. Various models, 3750, 3850, 9300. I think storing the database on flash may not be a good idea?
I have two sites with access switches connected via 1GB connection. SiteA has no servers but SiteB has a TFTP server that I can store the databases on.
Is it okay to use the TFTP server in SiteB for the switches in SiteA??  Also, what were to happen if that TFTP server happens to go down?
Reza Sharifi
You can use the flash and as long as you backup the config, you will always have a copy to load in case something happens. The flash does not go bad very often.
Should not be an issue if you want to go this route.
For redundancy install 2 servers.
I thought flash couldn't be used because it will fill up quickly?  I'd much prefer to keep it simple and use flash
As for redundancy, if I had two TFTP servers, how would I configure both? I thought it could be pointed to only 1 server?
It doesn't take much space to configure DHCP snooping on the access switches.  The config on the switch sits on NVRAM and not the flash.  So, if that is all you are doing, there is no need for flash space or any FTFP server.
The config sits on NVRAM, but doesn't the DHCP Snooping binding database sit on flash, and that's what takes up the space on flash?
