Configuring jumbo frames.
anil.radhakrishnan
Community Member
I have configured jumbo frames sized as 9198 in a 4948 switch using interface config mode inc the ether channel configured as trunk port.But after 10 min the switch stopped forwarding the frames.I would like to know is it possible to pass jumbo frames through a trunk or ether channel port between two switches.If so is this te possible wway to do this.One more doubt , what is the diffrence in configuring jumbo frames in global mode (system mtu < size> ) and int config mode (mtu <size>).Please help.
10 Replies 10
ankbhasi
Hi Anil,
Jumbo frames can be configured on etherchannel which are working in trunking mode. Jumbo frames are supported on nonblocking Gigabit Ethernet ports, and EtherChannels.
If you want to enable jumbo frames globally on all the ports so that you need not configure individually on all ports use "system mtu" command but if you want it for individual interface then configure on per interface basis.
But if you have configured on global mode with system mtu command and also on per interface basis then per-interface mtu command takes precedence over the system mtu command.
Can you specify if you have specified or changed mtu on interface basis or globally.
Also can you paste or attach the sh version from the switch.
Ankur
Hi Ankur,
Thank you for the reply.I have conbfigured in all the port , but using the interface config mode using the range command.Alos configured the uplink port which is an ether channel trunk port.But after doing this I can't able to ping to outside from the switch even to Default GW.So i just reset MTU to 1550.
Sh version
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(20)EWA,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 08-Sep-04 18:41 by kellythw
Image text-base: 0x00000000, data-base: 0x01224644
ROM: 12.2(20r)EW1
Dagobah Revision 225, Swamp Revision 4
sw-200-cr1(E9) uptime is 13 weeks, 2 days, 21 hours, 40 minutes
System image file is "bootflash:"
cisco WS-C4948 (MPC8245) processor (revision 0) with 262144K bytes of memory.
Processor board ID FOX0850056A
MPC8245 CPU at 266Mhz, Fixed Module
Last reset from PowerUp
3 Virtual Ethernet/IEEE 802.3 interface(s)
48 Gigabit Ethernet/IEEE 802.3 interface(s)
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Thanks alot,
Anil.
Hi Anil,
Make sure the port to which your uplink switch is connected also support jumbo frames. I believe you might have set the jumbo frames on uplink etherchannel ports but not on the device interface to which your etherchannel terminate.
If that device does not support jumbo frames then its better you move it back to 15xx.
Ankur
*Pls rate all helpfull post
Hi Ankur,
with this jumbo frame discussion i would also like question that, core switch 3750 jumbo frames enabled(as this switch doesn't support individual jumbo frames per port, so enabled jumbo frames globally), all servers connected on this switch are jumbo frames enabled, now one of the port is a trunking port connected to 2950T-24, all clients in this switch are 100Mbps, so if i enabled jumbo frames globally, it will enabled only in the 1000Mbps port or all the ports including 100Mbps as well as 1000Mbps?
Hi Anand,
Correct me if I am wrong, I believe you are looking for Jumbo Frame support on 2950T-24 switch.
AFAIK 2950 does not support jumbo frames and can max support baby giant frames upto 1530 and that too specific models
http://www.cisco.com/en/US/partner/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml#c5
Are you able to configure more that this on your 2950?
Ankur
Hi Ankur,
I think I configured jumbo frames only in the port channel.Not in the corresponding member physical interface.I have to check this out.Thank you for the response you have given.
Anil.
Hi Ankur,
Your right that 2950T-24 doesn't support more that 1500 bytes, so if i enable jumbo frames on 3750, what will happen if that 3750 is connected to 2950T-24? will it cause any data packet loss as 1 side 9000(3750) & other side 15000(2950)?
Hi Anand,
I believe you are connecting your 3750 to 2950 via gig ports. Its true that if you have enabled system mtu to 9000 on 3750 and because 2950 does not support jumbo frames, there will be packet loss.
It is always recommended that the ports which are having a communication between each other have to have the same MTU.
Ankur
*Pls rate helpfull post
certainly the problem will not be solved, as i need to looking for a 2950 switch will will support jumbo frame. any how thanks ankur for your replies. certainly will rate the post .
