Configuring NAT on a WS-C3560G-48TS switch
Arron_Harlow
In the event of our Cisco PIX failing we are preparing to recover our network. We only have access to our switches, so configuring NAT on the routers is not an option. Instead, we are looking in to the possibility of configuring our WS-C3560G-48TS, with the enhanced IOS, with NAT. Is this possible?
Thanks in advanced.
5 Replies 5
Jon Marshall
Unfortunately not. Only the 6500 switch supports NAT at this current time regardless of what version of IOS you run on the 3560.
Jon
luqmankondeth
The last time I checked , 3560s donot do nat.
Arron_Harlow
What if we use the cluster outside-interface command?
Still won't do NAT. You will need an external router or firewall to do NAT. No matter what you do to the switch it does not support NAT. See http://www.cisco.com/warp/public/473/166.html#topic1 (I think it was Jon pointed that out to me last week...)
Thanks a bunch, guys, for your help.
