Configuring Netflow/ Flexible Netflow over Cisco Catalyst 6513-E
MohamedCSE
Good Morning Dears,
Kindly note that i've a two Cisco catalyst 6513-E stacked togther over VSS. Sups are "Cat 6500 Sup 2T with 2 x 10GbE and 3 x 1GbE with MSFC5 PFC4". IOS is "s2t54 Software (s2t54-ADVENTERPRISEK9-M), Version 15.1(1)SY, RELEASE SOFTWARE (fc2)"
I was asked to configure our core switch for Netflow configuration, the target is to send the traffic flow between 10 user Vlans (source) to 2 server vlans (destination) to a flow exporter.
As per the below documents, I prepared the configuration as per the below
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080721701.shtml#confios1
conf t
mls netflow
mls flow ip full
! --Servers Vlans
interface Vlan110
ip route-cache flow
interface Vlan111
ip route-cache flow
! --Users Vlans
interface Vlan1
ip route-cache flow
interface Vlan2
ip route-cache flow
interface Vlan3
ip route-cache flow
interface Vlan4
ip route-cache flow
interface Vlan5
ip route-cache flow
interface Vlan6
ip route-cache flow
interface Vlan7
ip route-cache flow
interface Vlan8
ip route-cache flow
interface Vlan9
ip route-cache flow
interface Vlan10
ip route-cache flow
ip flow ingress layer2-switched vlan 1,2,3,4,5,6,7,8,9,10,110,111
mls nde sender version 5
ip flow-export source loopback 0
ip flow-export destination X.X.X.X 2055
ip flow export layer2-switched vlan 1,2,3,4,5,6,7,8,9,10,110,111
But while uploading it to the switch I got the following error “Warning: Command is no longer supported, please use Flexible NetFlow commands.”
Is the Flexible Netflow can give me the same functionality of older Netflow?  After a quick search I couldn’t find how to specify the source and destination vlan interfaces as before… any help?
Thanks in advance
