Configuring NetFlow in VRF Environment?
CiscoBrownBelt
Level 6
Level 6
You basically can use the same NetFlow monitor and apply it under any VRF forwarding interface on a switch or router correct?
Jaime Saldana Morales
Hi CiscoBlueBelt,
Yes Netflow will work with VRF's.
interface GigabitEthernet0
ip vrf forwarding test
ip address 1.1.1.1 255.255.255.252
ip flow monitor test output
Jaime Saldana
Hi CiscoBlueBelt,
Jaime Saldana
High what about IPSEC tunnels or any tunnel?
