Configuring Netflow on 6500 Switch
Hello All,
I have never worked on a 6500 prior to now and i was tasked to configure netflow and export data to Orion Solarwinds.
The config i entered on the switch is show below
All vlan and lo 0 have ip addresses
Switch(config)mls netflow
Switch(config)mls netflow ip interface-full
Switch(config)int vlan 2
Switch(config-if) ip route-cache flow
Switch(config-if) exit
Switch(config)int vlan 6
Switch(config)int vlan 7
Switch(config) ip netflow ingress layer2-switched vlan 2,6,7
Switch(config) mls nde sender version 5
Switch(config) ip flow-export source lo 0
Switch(config) ip flow-export destination 10.20.86.137 2055
Switch(config) ip flow-export layer2-switched vlan 2,6,7
Still, the data is not being exported to Orion NPM.
I have checked other documentations and configs differ slighty but no concrete solution.
Please any suggestions
milan.kulik
Level 10
Level 10
which IOS version are you running?
What do show mls netflow ip and  show mls nde commands display?
See  http://www.cisco.com/en/US/customer/products/hw/switches/ps708/products_configuration_example09186a0080721701.shtml#veri_
Best regards,
Milan
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
Displaying Netflow entries in Active Supervisor EARL in module 5
DstIP           SrcIP           Prot:SrcPort:DstPort  Src i/f          :AdjPtr
Pkts         Bytes         Age   LastSeen  Attributes
10.20.69.47     10.208.33.140   tcp :23168  :1529     Gi5/2            :0x0
1            52            12    16:23:40   L3 - Dynamic
10.20.71.84     176.32.98.230   tcp :www    :1545     Gi5/1            :0x0
13           14037         13    16:23:39   L3 - Dynamic
10.20.68.242    10.208.33.142   tcp :7833   :1373     Gi5/1            :0x0
1            52            13    16:23:39   L3 - Dynamic
10.64.4.158     10.20.6.16      tcp :5557   :1631     Vl6              :0x0
591          65306         24    16:23:52   L3 - Dynamic
10.48.132.87    140.207.54.36   tcp :8080   :34975    Gi5/1            :0x0
9            1836          61    16:23:23   L3 - Dynamic
10.32.9.11      10.20.31.70     udp :5000   :5100     Vl28             :0x0
12           552           28    16:23:49   L3 – Dynamic
hh-core-2#sh mls nde
Netflow Data Export enabled
Exporting flows to  10.18.69.137 (2055)
Version: 5
Layer2 flow creation is enabled on vlan 2,4,6-7,10,12,14,20,28
Layer2 flow export is enabled on vlan 2,4,6-7,10,12,14,20,28
Include Filter not configured
Exclude Filter not configured
Total Netflow Data Export Packets are:
    542551 packets, 0 no packets, 15733692 records
Total Netflow Data Export Send Errors:
        IPWRITE_NO_FIB = 0
        IPWRITE_ADJ_FAILED = 0
        IPWRITE_PROCESS = 0
        IPWRITE_ENQUEUE_FAILED = 0
        IPWRITE_IPC_FAILED = 0
        IPWRITE_OUTPUT_FAILED = 0
        IPWRITE_MTU_FAILED = 0
        IPWRITE_ENCAPFIX_FAILED = 0
        IPWRITE_CARD_FAILED = 0
Netflow Aggregation Disabled
I can see
but
in your config.
Are you exporting to the correct collector on the correct port?
If yes, isn't there any FW or an ACL blocking the NetFlow traffic on the path?
Bets regards,
Milan
Hello Milan,
Thanks for your reply.
The correct endpoint is 10.18.69.137 2055.
There is no ACL on the switch denying traffic.
I added an ACL to allow netflow traffic aswell.
Still traffic is not being exported.
Thanks for you help
Mike
