ACL Issue in Catalyst
JPavonM
Even in Catalyst 3750 and 4500 with ip services IOS, when I apply an ingress extended ACL in an VLAN interface to deny some kinf of traffic (ICMP), this traffic only match de permit ip any any sentence. Is there any limitation with ACL traffic restriction in such models?
This is the configuration:
interface Vlan10
ip address x.y.z.1 255.255.255.0
no ip redirects
no ip unreachables
ip access-group 101 in
ip access-list extended 101
deny icmp any x.any
permit ip any any
6 Replies 6
cadet alain
which type of icmp is entering this Vlan that doesn't get a hit ?
Alain
Thank you Alain for your answer.
The type of ICMP is ping, we want to disable ping  from a specific IP in that VLAN
SW#sh access-l
Extended IP access list 101
    10 deny icmp any host x.y.z.1 echo-reply
    20 deny icmp any host x.y.z.1 echo
    30 permit ip any any (59 matches)
The destination IP must be in another VLAN, is it in the VLAN where you apply the ACL ? in which case do you want to prevent pings within that VLAN or to another VLAN ?
in first case then use a VACL or an ingress PACL and in second case use a RACL like you did but put the host IP as source instead of destination.
Alain
Thank you again Alain, but still not working.
I know about VACL and PACLs but ithis case is a RACL. The problem is ping's are still working between both VLANs.
VLAN 10 is the destination (a.b.c.0/24)
VLAN 28 is the source (x.y.z.0/24)
I have modified the ACL so I can apply it to any VLAN interface:
ip access-list extended ping
deny   icmp a.b.c.0 0.0.0.255 x.y.z.0 0.0.0.255
deny   icmp x.y.z.0 0.0.0.255 a.b.c.0 0.0.0.255
permit ip any any
And then I have applied it to both ways (ingress and egress) in every VLAN interface this way:
interface Vlan10
ip address a.b.c.3 255.255.255.0
ip access-group ping in
ip access-group ping out
interface Vlan28
ip address x.y.z.3 255.255.255.0
Anyway, no ICMP is filter out when I ping from a host in VLAN 28 to a host in VLAN 10:
Extended IP access list ping
    1 deny icmp 172.31.10.0 0.0.0.255 192.168.128.0 0.0.0.255
    2 deny icmp 192.168.128.0 0.0.0.255 172.31.10.0 0.0.0.255
    20 permit ip any any (1129 matches)
Hi Jesus,
your configuration looks good, can you please confirm that access list is applied on the switch where intervlan routing is happening for these VLANs right ?
Manish
Problem solved, it seems that the routing of the customer was through a firewall, not in the catalyst itself.
Kind regards to all of youo for your help.
Jesus
