Configuring PBR on Cisco 3750E
Nkechi Latunji
I have a cisco 3750E running c3750e-universalk9-mz.122-53.SE2.bin. The ip policy route-map command is not available under the SVI. Any ideas why?
Does this switch not support PBR?
I configured the sdm prefer routing and rebooted, still the command is not available
Chris
6 Replies 6
joshiaroon
You can try searching on cisco feature navigator.
Nagaraja Thanthry
What license you have on the box? PBR needs IP Services feature set. So, if you have just the base license, then you might need to get the IP Services license. Hope this helps.
NT
Besides the IPServices image, you also need to change the SDM from "Desktop Default" to "Desktop Routing". i.e. (config)#sdm prefer routing.
This is the image I am running on the switch c3750e-universalk9-mz.122-53.SE2.bin. Only IP Base and this image are available for download, no  IP Services. I already tried the sdm prefer routing
The IP Services is a licensed feature. You might have to contact your reseller and see if you can buy the license. The feature is already present in the image but is not enabled because of the license. Hope this helps.
NT
wang baojun
hello,
i have the feature you want  in this platform ,if you want it , contact me in msn.
