Configuring Port Channel in CLI - ACI
KeithGebhardt
I've been poking around trying to figure out a way to create port channels in the CLI rather then the GUI.
The set of instructions below is how we would typically configure a port channel in the GUI, and we are not having any luck getting these configurations in the CLI. Anyone familiar with doing this in the CLI? Any information would be very helpful. Thank you.
- Navigate to each of the following ethernet ports
leaf_hostname eth1/4
In operational tab:
Description: asset_hostname(po)
[SUBMIT]
leaf_hostname eth1/5
In operational tab:
[SUBMIT]
leaf_hostname eth1/6
In operational tab:
[SUBMIT]
leaf_hostname eth1/7
In operational tab:
[SUBMIT]
-Creating the VPC interface:
Fabric > Access Polices > Interfaces> Leaf Interfaces> Policy Groups > PC Interface
1.) Right Click "PC Interface" in the left nav panel and select "Create PC Int Policy Group"
2.) Fill in the dialog:
-Name: asset_hostname
-Description: asset_hostname
-Attached Entity Profile: <name>
-CDP Policy: <CDP_Disabled>
-Link Level Policy: <Link_Auto_Negotiate>
-Port Channel Policy: <PC_Static_On>
-LLDP Policy: <LLDP_Enabled>
-Monitoring Policy: <Access_Monitoring_Policy>
[SUBMIT]
-Add the profile group to created above appropriate leaf profiles "Access Port Selector"
Fabric > Access Policies > Interfaces > Leaf Interfaces > Profiles > leaf_hostname > E1_04
1.) Right Click "E1_04"
2.) Policy Group: <asset_hostname_po1>
3.) Double Click 1/04 under "Interfaces"
4.) Description: asset_hostname_po1
[SUBMIT]
Fabric > Access Policies > Interfaces > Leaf Interfaces > Profiles > leaf_hostname > E1_05
1.) Right Click "E1_05"
3.) Double Click 1/05 under "Interfaces"
[SUBMIT]
Fabric > Access Policies > Interfaces > Leaf Interfaces > Profiles > leaf_hostname > E1_06
1.) Right Click "E1_06"
3.) Double Click 1/06 under "Interfaces"
[SUBMIT]
Fabric > Access Policies > Interfaces > Leaf Interfaces > Profiles > leaf_hostname > E1_07
1.) Right Click "E1_07"
3.) Double Click 1/07 under "Interfaces"
[SUBMIT]
>> Assogiate EPG's
0 Replies 0
