Configuring port-channel on N7K
ramadanhussein
Hi there,
I am trying to build a port-channel from N7K-01 to N7K-02 using a breakout cables (40G interface from N7K-01 to 4x10G interfaces on N7K-02). it didn't work
is this require a special configuration??? because I have done port-channel configuration between two 40G interfaces and it works.
appreciate your valuable support if possible to share the needed configuration to accomplish this.
thanks,
regards,
Haitham.
Reza Sharifi
Do you see link lights on the 10Gig sides?
What is part number for the cable you are using?
when I do it directly between cisco ASR9k, the 10g interfaces are up with lights but 40G side is red not up.
between cisco N7Ks, no lights from both sides. between N7Ks cable is going to patch-panel and then to other nexus.
thanks,
