Configuring qos trust on port-channel
wfqk
Level 5
Level 5
Hi One switch 3560 is connected to 4500 through two interfaces, which are bound as port-channel and as layer 2. Under the 3560, there are some PC and ip phone. so we use auto qos at each interface of 3560. Now we also need to configure auto qos voice trust on the port-channel. but 3560 port-channel does not support auto qos. How can we resolve the issue? Thank you
8 Replies 8
I would configure the interfaces with auto qos voip trust command before adding them to the port-channel.
For example, if interfaces gi0/1 and gi0/2 are members of the port-channel 12, I will configure as follows:-
interface range gi0/1 - 2
 auto qos voip trust
 channel-group 12 mode active
 no shut
HTH,
Meheretab
HTH,
Meheretab
Thank you so much for your reply. Do you think if the port channel would removed the feature on the physical interface if the port channel does not have the config?
Please look at the example configuration on 3560-CG switch running IOS 12.2(55) below:
SW1#sh version
Cisco IOS Software, C3560C Software (C3560c405ex-UNIVERSALK9-M), Version 12.2(55)EX3, RELEASE SOFTWARE (fc2)
1) Before starting the configuration:-
SW1#sh run int gi0/5
Building configuration...
Current configuration : 36 bytes
interface GigabitEthernet0/5
end
SW1#sh run int gi0/6
interface GigabitEthernet0/6
end
2) Configure both interfaces by first configuring etherchannel :-
SW1(config)#int range gi0/5 - 6
SW1(config-if-range)#channel-group 11 mode on
Creating a port-channel interface Port-channel 11
SW1(config-if-range)#auto qos voip trust
AutoQoS Error: AutoQoS can not be configured on member port(s) of a port-channel
% Range command terminated because it failed on GigabitEthernet0/5
SW1(config-if-range)#do sh run int gi0/5
Current configuration : 62 bytes
end
3) Remove the channel-group and configure the auto qos first:-
SW1(config-if-range)#no channel-group 11
SW1(config-if-range)#end
4) Configure trunk and other configurations on the etherchannel :-
SW1(config)#int po11
SW1(config-if)#switchport trunk encapsulation dot1q
SW1(config-if)#switchport mode trunk
SW1(config-if)#end
5) Once you are done configuring :-
Current configuration : 237 bytes
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
end
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
end
SW1#sh run int port-channel 11
Current configuration : 93 bytes
interface Port-channel11
end
Remember that when you delete the port-channel, you will lose connectivity until you configure it back.
Feel free to ask further if you have more questions.
HTH,
Meheretab
HTH,
Meheretab
The question is if auto qos or mls qos is needed on the port-channel in this situation. If it is yes, it seems that these commands cannot be supported on the port-channel
Its for physical interfaces only not logical port-channels interface itself , not supported as you seen
Can we say we only config qos on physical interface and do not need to configure qos on port-channel?
Yes.
