Configuring Root Bridge Primary and Secondary on a Switch Stack
tonymitchell
Hi, Consider a small LAN using a collapsed core design with two Catalyst 3650 switches in a stack as the core/distribution layer. There are several 2960X switches with cross-stack EtherChannels to the 3650's. After enabling Rapid-PVST, best practice would be to configure the root bridge. The question is, would it be sufficient to configure the stack to be the Root Primary and not configure a secondary, based on a failure of the stack master switch would elect the slave to become the stack master and effectively become the root bridge?
Tony
Jon Marshall
Tony
You shouldn't need to configure a secondary root on the same switch stack because there is only one configuration file that is used for all stack members.
So, as you say, if the current stack master fails then a new one is elected and it will use the existing running configuration which has the STP root set.
Jon
Jon Marshall
Tony
Jon
Thanks Jon.... just wanted to sanity check that, as I couldn't find a configuration example anywhere!
Kind Regards
Tony
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
BTW, don't know if issue also applies to 3650 stacks, but on 3750 stacks, if stack master fails, I believe your port channels will reset because, by default, stack's MAC changes.  However (again at least for 3750s), the stack can be configured to retain the original master MAC.
