Configuring SPAN On Cisco Nexus System version: 5.0(2)N2(1)
Rupesh Kolatwar
Hi all,
I am Configuring SPAN On Cisco Nexus System version: 5.0(2)N2(1), i am running the issue as below (down (Src in wrong mode)
switch01# show monitor session all
   session 1
type              : local
state             : down (Src in wrong mode)
source intf       :
    rx            : Eth1/3
    tx            : Eth1/3
    both          : Eth1/3
source VLANs      :
    rx            :
source VSANs      :
    rx            :
destination ports : Eth1/9
Legend: f = forwarding enabled, l = learning enabled
   session 2
type              : local
source intf       :
    rx            : Eth1/4
    tx            : Eth1/4
    both          : Eth1/4
source VLANs      :
    rx            :
source VSANs      :
    rx            :
!Command: show running-config interface Ethernet1/3
!Time: Wed Nov  4 14:23:48 2015
version 5.0(2)N2(1)
  switchport mode trunk
  switchport monitor
  switchport trunk allowed vlan 1006-1019,1118-1119,3041-3043
destination port configured as below
show running-config interface Ethernet1/9
!Time: Wed Nov  4 14:24:02 2015
version 5.0(2)N2(1)
  switchport monitor
  speed 1000
please let me know if am doing anything wrong....!!!
7 Replies 7
Ganesh Hariharan
Hello Rupesh,
I see only half the configiration, Have you configired the span in below fashion.
Configure SPAN
switch# configure terminal
switch(config)# monitor session session-number
Destination Port Configuartion
switch(config)# interface ethernet slot/port
switch(config-if)# switchport monitor
switch(config-if)# exit
switch(config-monitor)# destination interface ethernet slot/port
Source Port Configuration
switch(config-monitor)# source interface ethernet slot/port
Hope that Helps..
-GI
Rate helpful Posts
Hi Ganesh,
I have followed the same as steps above but still i am getting this error
switch01(config)# configure terminal
switch01(config)# monitor session 1
switch01(config-monitor)# exit
switch01(config)# interface ethernet 1/40
switch01(config-if)# switchport monitor
switch01(config-if)# exit
switch01(config-monitor)# destination interface ethernet 1/40
switch01(config-monitor)# monitor session 1
switch01(config-monitor)# source interface ethernet 1/3
switch01(config-monitor)# do copy running-config  startup-config
switch01(config-monitor)# show  monitor session 1
   session 1
type              : local
source intf       :
    rx            : Eth1/3
    tx            : Eth1/3
    both          : Eth1/3
source VLANs      :
    rx            :
source VSANs      :
    rx            :
destination ports : Eth1/40
switch01(config-monitor)# show interface ethernet 1/3
Ethernet1/3 is up
  Hardware: 1000/10000 Ethernet, address: 0005.73dd.ed8a (bia 0005.73dd.ed8a)
  Description:
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is on
  EtherType is 0x8100
switch01(config)# show interface ethernet 1/40
Ethernet1/40 is up
  Hardware: 10000 Ethernet, address: 0005.73dd.edaf (bia 0005.73dd.edaf)
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  Last link flapped 00:00:22
Hi Ganesh, did you get bottom of this , I having the same issue.
asavarin
Switchport monitor command has to be enabled only destination port . If you enabled "switchport monitor" under  source port then you will observe your session state as "state             : down (Src in wrong mode)" . So remove switchport monitor command under source port.
Many Thanks asavarin for updating, figured it bit late.
Cheers
Hello
Try the following:
int rang eth1/3,eth1/9
shut
monitor session 1
source interface ethernet 1/3 both
destination interface ethernet 1/9
int ethernet 1/9
switchport monitor
no shut
int eth1/3
no shut
Kind Regards
Paul
Gabriel Voitis
Metro.1.New(config)# int e1/8
Metro.1.New(config-if)# switchport ?
<CR>
<CR>
Software
BIOS: version 05.51 [last: 05.28]
NXOS: version 9.3(13)
BIOS compile time: 11/29/2023 [last: 01/18/2018]
NXOS image file is: bootflash:///nxos.9.3.13.bin
NXOS compile time: 1/31/2024 12:00:00 [12/13/2023 06:06:50]
The new NXOS dont have "switchport monitor"
Any others ideas?
Metro.1.New#
Metro.1.New# show monitor session all
session 1
type : local
state : down (Dst in wrong mode)
acl-name : acl-name not specified
source intf :
rx : Eth1/6
tx : Eth1/6
both : Eth1/6
source VLANs :
rx :
tx :
both :
filter VLANs : filter not specified
source fwd drops :
destination ports : Eth1/8
source VSANs :
rx :
Metro.1.New#
Gabe
