12-29-2014 09:10 AM - edited 03-07-2019 10:02 PM
I will be setting up 2 x 4500x switches as a VSS pair and then will have 2 MECS (Multi-chassis Etherchannels) down to 2 stacks of 3750x switches. I am preparing the config and would really appreciate is someone can verify I have put together the correct config. I don't have access to the switches yet so cannot test it.
So for the VSS config.......(Using virtual domain 10, channel group 3)
4500X-01
Switch virtual domain 10
Switch 1
mac-address use-virtual
Interface port-channel 3
switchport
switch virtual link 1
no shut
Interface range Tengig 1/1/15 - 16
switchport mode trunk
channel-group 3 mode on
Switch convert mode virtual
4500X-02
Switch 2
switchport
switch virtual link 2
no shut
For Dual Active Detection......
dual-active detection fast-hello
exit
Interface Tengig 1/1/14
dual-active fast-hello
no shut
Interface Tengig 2/1/14
no shut
Now for the MEC configs...... (Im using channel goups 1&2 on the 4500x vss pair and port-channel 1 on 3750 Stack1 and channel group on 3750x stack2)
Core 4500x
interface port-channel1
description MEC1-TO-3750X
switchport
interface port-channel2
description MEC2-TO-3750X
switchport
interface range Tengig 1/1/1 - 2/1/1
channel-group 1 mode ON
interface range Tengig 1/1/2 - 2/1/2
channel-group 2 mode ON
3750X Stack 1
Interface port-channel 1
Description MEC1-TO-4500X
udld port aggressive
3750X Stack 2
Interface port-channel 2
Description MEC2-TO-4500X
I am using mode ON for both ends, is this good practice or is it best using Active modes for LACP
Any help will be appreciated
Solved! Go to Solution.
12-29-2014 09:33 AM
For the most part the config is correct. There is one thing that needs to be modified. For the VSL link you are using po3 on both switches. The port-channel numbers need to be different for each switch.
So, if you are using po3 for switch-1, you need to configure po4 on switch-2.
Have a look at the VSS config section "Configuring VSL Port Channel and Ports"
This link is using po10 and 20.
Link:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1-2/XE_340/configuration/guide/config/vss.html
12-29-2014 09:33 AM
Link:
12-29-2014 09:37 AM
One more thing, for MEC, it is recommended to use LACP or PAgP.
12-30-2014 01:49 AM
Hi Reza
Thanks for your feedback. I always tried to use the same numbers on either end for port-channels so wasn't aware they need to be different for VSS. But thanks again, ive learnt something new :-)
