Conflict between two VLANs
sagarshaha
Beginner
Beginner
We have a strange problem here....let me give you some background of my setup.
We have Cisco 3560X L3 swtich with 2 VLANs configured as mentioned below
VLAN1 - Server VLAN (192.168.0.1/255.255.254.0) (Swtich Port - Gi0/2 to 0/10)
VLAN2 - User VLAN (192.168.152.1/255.255.248.0) (Swtich Port - Gi0/11 to 0/22)
We have connect L2 switches on respective VLANs and then the servers and user LANs respectively. We have configured the DHCP server on this switch to get the IPs to LAN users from VLAN2.
So, as per the configuration done in the swtich, all the user should receive the IPs from 192.168.152.0/255.255.248.0 range from DHCP server but some of users receives the IP from VLAN1 which 192.168.0.X something like this.
When we do IP reset/renew it goes back to normal behaviour and assigns the IP from 152.X series.
This happends daily to most of our users.
Can someone please help us here?
Thanks in advance.
Sagar
18 Replies 18
Abzal
Rising star
Rising star
1. It could that User's PC connected to port that assigned to VLAN 2. You may check ports if it has wrong VLAN.
2. Users move and connect to wall socket that configured to VLAN 2.
You may assign ports to VLAN 2 only that connect to Server and all other ports to VLAN 1.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Hi Abzal,
Thanks for your reply.
I think mby mistake you wrote VLAN2 instead of VLAN1, as I said VLAN2 is USER VLAN and VLAN1 is SERVER VLAN.
Anyways, I understand the point and here are the answers.
1. It could that User's PC connected to port that assigned to VLAN 1. You may check ports if it has wrong VLAN.
Ans ->We have connected L2 switches from VLANs, so the workstations cables are not directly connecting to VLANs.
So, the route is User->L2 switch->VLAN2
2. Users move and connect to wall socket that configured to VLAN1
Ans-> We have not configured ANY wall socket to VLAN1 as they are only for our server room.
Yes, we have done the same thing. All the ports from G0 to G10 are for server VLAN and G11 to G22 are for User VLAN.
Thanks in advance.
Sagar
Ok then. Can you show DHCP pools and SVIs configuration.
And output from 3560:
sh int trunk
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Here you go....
VLAN config...
L3(config)#interface vlan 1
L3(config-if)#ip address 192.168.0.1 255.255.254.0
L3(config-if)#no shutdown
L3(config-if)exit
L3(config)#interface vlan 2
L3(config-if)#ip address 192.168.152.1 255.255.248.0
L3(config-if)exit
L3(config-if)#end
L3#wr
DHCP Config...
L3(config)#service dhcp
L3(config)#ip dhcp pool XXXX
L3(dhcp-config)#network 192.168.152.0 /21
L3(dhcp-config)#domain-name XXXX.com
L3(dhcp-config)#dns-server 192.168.0.75 192.168.0.76 202.56.230.5 4.2.2.2 8.8.8.8
L3(dhcp-config)#default-router 192.168.152.1
L3(dhcp-config)#lease 7 0 0
L3(dhcp-config)#exit
L3(config)#ip dhcp excluded-address 192.168.152.1 192.168.152.100
L3(config)#exit
L3#wr
sh int trunk Output...
L3>show int trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi0/1       on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi0/1       1-4094
Port        Vlans allowed and active in management domain
Gi0/1       1,10,20,30
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/1       1,10,20,30
L3>
Sagar
One question:
What device is connected on port G0/1? Is it L2 switch where users resides? This port not allowing VLAN 2 to 3560.
sh run int g0/1
Have you created VLAN 2 on that switch?
sh vlan
sh spanning-tree vlan 2
sh int trunk
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Hi Abzal,
G0/1 is connected to Firewall. Its a trunking port.
Yes, all VLANs are configured on this 3560X switch.
sh run int g0/1 output....
L3#sh run int g0/1
Building configuration...
Current configuration : 97 bytes
interface GigabitEthernet0/1
switchport mode trunk
end
L3#
sh vlan output....
User Access Verification
Password:
KOMLI_L3>sh run int g0/1
% Invalid input detected at '^' marker.
KOMLI_L3>en
Password:
KOMLI_L3#sh r
KOMLI_L3#sh run int g0.1
KOMLI_L3#sh run int g0/1
end
KOMLI_L3#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Gi0/23, Gi0/24
10   SERVERS_SW            active    Gi0/2, Gi0/3, Gi0/4, Gi0/5,Gi0/6,Gi0/7, Gi0/8, Gi0/9, Gi0/10
20   USERS_SW                 active    Gi0/11, Gi0/12, Gi0/13, Gi0/14, Gi0/15, Gi0/16, Gi0/17, Gi0/18, Gi0/19,
                                                       Gi0/20, Gi0/21, Gi0/22
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
10   enet  100010     1500  -      -      -        -    -        0      0
20   enet  100020     1500  -      -      -        -    -        0      0
30   enet  100030     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
--More--
sh spanning-tree vlan 2....
L3#sh spanning-tree vlan 20
VLAN0020
  Spanning tree enabled protocol ieee
  Root ID    Priority    32768
             Address     40f4.ecf1.695a
             Cost        20004
             Port        7 (GigabitEthernet0/7)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32788  (priority 32768 sys-id-ext 20)
             Address     442b.0393.4800
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi0/1               Desg FWD 4         128.1    P2p
Gi0/11              Desg FWD 4         128.11   P2p
Gi0/12              Desg FWD 4         128.12   P2p
Gi0/13              Desg FWD 4         128.13   P2p
L3#
Thanks for your help !!
Sagar
Now it's a little bit unclear. Network diagram will be better with port connected.
Your topoly look like this?
users --- L2 switch ----g0/? 3560  g0/1 ----- Firewall
Is the port between L2 switch and L3 3560 configured as a trunk?
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Yes, as mentioned by you, the topology is correct.
User->L2 switch->User VLAN(G0/X) -> G0/1(Trunk Port)->Firewall
None of the ports on L3 switch are configured as Trunk except G0/1
Sagar
But if my topology is correct then you should configure the port L2 swtich and L3 3560 as a trunk.
Show some outputs from L2 switch:
sh run
sh int trunk
And create VLAN 2 on L2 switch. Why IPs 192.168.152.1 and 192.168.0.1 are configured under VLAN 1 and VLAN 2 interface respectively. Or it just typo? Because you created VLAN 10/VLAN 20 but not VLAN 2 on KOMLI_L3 switch.
Suggestions:
1. Create VLAN 2 on all user switches.
2. Configure between ports L2 and L3 switches as a trunk.
3. Assign correct VLAN on ports (Users, Servers).
Verification:
sh vlan ---> to verify vlan database
sh int trunk  ----> VLANs needs to be allowed VLAN 1/VLAN 2
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Hi Abzal,
Yes, its just a typo....we have VLAN10 and VLAN 20
L2 switches are just normal switches and we have not configured anything onto it. They are currently acting like unmanaged switch.
Please suggest.
Sagar
Hi Sagarshaha,
This could well be an issue with a Malware on one of the user  PCs and nothing to do networking. ( I have gone through this before ). If one of the user PCs has a malware that replies to DHCP request, some of the PC's will end up getting IP address from the malware..
To figure this out, You can install Wireshark on a Laptop/PC ( one without a malware.. )  and plug that in one of the ports on VLAN2, filter only for DHCP traffic and start renewing DHCP IPs on each PCs while closely looking at the DHCP offers on Wireshark, if you see an offer coming from some IP other than the switch's SVI, that's your culprit.
Remove it from the production.. Clean it up before putting it back on.
Let me know how what you find..
Also don't forget to rate helpful answers.
Shamal
Hi shamal,
we have ~180 users and its difficult to release/renew dhcp address on each of the laptops. Can you please suggest me some work around so I can find the culprit either from my switch?
Many Thanks,
Sagar
Hi Sagar,
In order to eliminate the possible issue caused by ohter malware PC's on the network, next time when you find a user pc picking DHCP ip address from server vlan, do a ip config/all on that PC and verfy what is the dhcp server ip address it is showing up there. If it is anything other than the L3 interface of your switch then you can suspect a rogue pc on your network.
If you identify the DHCP server address is showing up anything other than L3 device you can trace back the culprit ip address and try removing from the network.
It is would have been helpful for every one if you had a topology (how the above said devices are connected) and running configurations on them.
Najaf
Please rate when applicable or helpful !!!
Hi Najaf,
Yes, we did ipconfig/all on the PC and it picks up the IP from Server VLAN pool only. It is nothing from outside the network.
I have attached my current simple network architecture diagram.
Hope this is helpful !!
Recognize Your Peers
