Native vlan tagging and vty access to Autonomous APs
trevormark
Hello and thanks for reading!
I've been experimenting with the 'vlan dot1q tag native' command on a switch and it seems as though tagging the native vlan breaks vty access to my access point.
With the 'vlan dot1q tag native' commnand applied, I lose management connectivity to the AP with 'no vlan dot1q tag native' applied, connectivity is restored. Why is this? Is it safe to say that one can access the AP via vty lines using ONLY untagged packets?
Can anyone shed light on this?
SWITCH
Model: WS-C3560G-24PS
Code: c3560-advipservicesk9-mz.122-46.SE
--Abbreviated CONF
interface GigabitEthernet0/1
description AIRONET
switchport trunk native vlan 2
switchport trunk allowed vlan 2,4,8,16
switchport mode trunk
ACCESS POINT
Model: AIR-AP1042N-A-K9
Code: c1140-k9w7-mx.124-25d.JA1
--Abbreviated CONF
interface Dot11Radio0.2
encapsulation dot1Q 2 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.2
no ip route-cache
bridge-group 1
14 Replies 14
Andras Dosztal
Level 3
Level 3
This config was copied from one of my operating 1131AG APs:
Switch:
interface FastEthernet0/21
description AP
spanning-tree portfast
spanning-tree bpduguard enable
AP:
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
no cdp enable
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface FastEthernet0.2
description Management
no ip route-cache
bridge-group 1
interface FastEthernet0.3
description SSID
no ip route-cache
no cdp enable
bridge-group 3
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address
no ip route-cache
trevormark
Andras,
Is native vlan tagging enabled on this switch?
kcnajaf
Level 7
Level 7
Hi Trevormark,
By default native vlan traffic is untagged vlans on the trunk link as you may be aware. The rule of thumb is that if you are using a specific vlan as native vlan on the trunk then you should ensure that the device connected to the other end of trunk port also has the same vlan configured as native vlan.
So from your configuration wise you have "switchport trunk native vlan 2" on the switch trunk and you have "
encapsulation dot1Q 2 native" on the radio and gig sub interfaces on the AP. This configurations are correct since you have the same native vlan used on the both ends of a trunk link. This means VLAN 2 traffic will not be tagged while passing through the trunk link.
But when you apply "vlan dot1q tag native" on the switch end you are asking the switch to tag the native vlan (in your case this means vlan 2 traffic will be send to AP as tagged). Now you have a mismatch of configuration where in you are tagging vlan 2 at the switch end and the AP end you not tagging vlan 2 and hence AP will reject all tagged vlan2 packets.. This will result in communication failure between these two devices and that is the reason why you lose access to the VTY.
Hope this helps.
Najaf
Please rate when applicable or helpful !!!
trevormark
Najaf,
Since 'vlan dot1q tag native' is a global command, how is one supposed to access an AP that drops all tagged traffic on its native vlan?
Can you try giving
Hello Trevor,
I got to admit.. I am not an Wireless expert ( Not even close to that ) but I had a case yesterday with an ASA a layer 2 switch and an AP and this device for managment purposes was only available using untagged packets but we still need it to send tagged packets for the rest of the user traffic.
That being said.. I would say via console cable lol .... But why dont you send the user traffic tagged and then just use a particular vlan for the AP so you can access it ???
That way is a win win
Hope I could help
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
jcarvaja,
'vlan dot1q tag native' is a global command, meaning it is either applied or its not. When it is applied, all vlans are tagged.
Hello Trevor,
I know what that command does, that is why I provided you the solution already,  and as I already said the AP will only accept untagged packets on its vty lines, so again use a trunk link allowing the users vlans and put the AP on the untagged ( native) vlan on that trunk,
As simple as that, I got it working 2 days ago with that..
So nothing to worry. Expected behavior
Julio Carvajal
Hi Trevormark
Believe me you have asked an interesting question but unforutnatly i dont know the answer for the same :-(
Also i dont have a lab to test this out :-(
Could you try removing the the native commands on the trunk port and access point and check if you are able to ping between them.
It will be interesting to know the result :-)
Najaf
Hi Trevormark,
"Since 'vlan dot1q tag native' is a global command, how is one supposed to access an AP that drops all tagged traffic on its native vlan?"
I believe , user vlans are in other vlans and your management vlan in vlan 2 which is Native.
You are tagging vlan 2 on switch side as '" vlan dot1q tag native" command will tag all the vlans including native vlan and AP will drop this traffic as AP will expect untagged traffic from vlan 2.
Users traffic is not affected as packet tagged on both side.
V.S.Suresh .
Najaf,
Apparently the APs will ONLY allow untagged traffic on their vty lines. This was confirmed by Scott Fella in another users thread.
By this logic, your suggestion of removing the 'native' option on the trunk as well as the AP, will have no effect since the switch would still be sending tagged traffic.
That said, the options are to disable 'vlan dot1q tag native' or attach the AP to a different switch in the topology that does not have native vlan tagging enabled.
Trevor
Hi Trevormark,
It looks like every day is a school day where i learn some thing new :-)
Thanks for confirming the point that AP's does not allow untagged packets on management interface. If Scott has said that then that would be the fact as I know he is an expert in wireless :-)
So to conclude if we have 'vlan dot1q tag native' enabled globally on a switch then we can not have any AP's (with switch port configured as trunk) connected to any port of this switch accessible through the vty because switch will send tagged packet over the trunk link and AP's does not accept tagged packet on management interface. PLEASE CONFIRM IF MY UNDERSTANDING IS CORRECT HERE...
Scott,
I'm sure that you would be going through this post (as this is related to AP) and hence please confirm my understanding is correct here.....
Thanks in advance.
Najaf
trevormark
Najaf,
I believe you understand it correctly. There is one caveat I see however. For security purposes, enabling native vlan tagging AND configuring a switchport as trunk with an AP attached disables management access entirely (via vty). We could then limit management access to console port (if acceptable). The AP is then quite secure and still functions normally for wireless users.
Trevor
Hi Trevomark,
I labbed this up today.
Interestingly result is that even with the vlan dot1q tag native command enabled globally on the switch i was able to reach the AP's management address which was against as per our theory.
As per the original posted the AP was not reachable after enabling vlan dot1q tag native globally but surprisingly for me, the AP was pinging even when the switch was sending tagged packet to the AP with vlan dot1q tag native command enabled globally
I have attached the details of my test bed.
Does any one have any clue for this?
Najaf
