Confused: Connecting 2 buildings with 3560 Switches
mconway
Here goes ... the problem:
I will have 2 physically seperated buildings on the same lot connected via fiber optics at each end are 3560 switches that will do routing.  Each building will be on it's own subnet.
Building A is 10.0.0.0/24 VLAN 1 (Which currently has (4) 3560 switches daisy chained together).  I would like to move all the devices connected to these switches to a diffrent VLAN.  This will be where the majority of the servers will remain.
Building B will be 10.1.0.0/24 VLAN 10.
My plan is to install a Domain Controller on 10.1.0.0/24.
How do I configure the switches to route correctly between themselves and have 10.1.0.0/24 route internet traffic through a PIX on 10.0.0.0/24 ip 10.0.0.1/24.   I'm leary of making changes to the existing 10.0.0.0/24 because of it being live.
17 Replies 17
Michael Conway wrote:
In the past when I have configured an LACP link between a server and a switch I could see the connection speed on the virtual adapter that is created when teaming on the server.  How do I check the speed with 2 switches connected via a LACP Trunk?
In darren's example he creates the port-channel with the encapsulation dot1q then also configures each interface with dot1q encapsulation that will be in the port-channel.  Is there a reason for this?  Seems double redundant?  Is this for failover?
The reson for that is simple - in a Cisco encironment, the individual interfaces won't join a port-channel group unless they are all meeting certain criteria - amongst those criteria are a requirement for the ports to be in the same mode as the port-channel interface. Hence, the same mode on the port-channel group and the individual ports.
Think of the individuaal ports as a sub-port of the port channel, if it helps. The configuration which holds on the port-channel interface flows down to the individual ports, something like this (I suck at ASCII art, so I hope this comes out OK)
                    |------------interface 1
                    |            (inhereted configuration)
PO interface--|
                    |------------interface 2
The difference is that the configuration doesn't automatically "inheret" to the individual ports - you have to manually configure them to match,
Also, all ports in a port-channel have to be the same speed/duplex or they won't join the group either.
As far as checking the speed of the amaglamated interface - you can look at the port-channel interface itself- show interface po1, for example. This will show you the total throughput rate of the port channel across all its members.
Cheers.
mconway
Makes sense about interfaces needing defining thanks.
Next question about the PIX 506E that we use.
The existing internal network is 10.0.0.0/24 that we use.
What would be the correct NAT statement to use to allow NAT translation of 10.1.0.0/24?
Currently:
access-list 101 permit ip 10.0.0.0 255.255.255.0 192.168.100.0 255.255.255.0  // Believe this is for VPN connection
nat (inside) 0 access-list 101
nat (inside) 1 10.0.0.0 255.255.255.255 0 0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
Also are there any open source VPN client software avaible to work this PIX?
Currently:
What version of OS is the PIX running?
I haven't used a PIX in years, and the ASA I use is a bit different - you might be better putting this question in the Firewalling format - you're more likely to get an answer from people who use PIX's.
If you do move the PIX question, can you mark this one as "answered" for future reference.
Cheers.
