confused with subnetting class c addresses and b classes
John Cheetley
Level 3
Level 3
Hi Team,
224.16.196.51 /29
CIDR binary is 11111000 (last octet)
2 to the power of 5 = 32 -2 = 30 (subnets) (for the 1's)
2 to the power of 3 = 8 - 2 = 6 (hosts) (for the 0's)
Mask is 256 - 248 = 8 (magic)
Network ID
224.16.196.0
Broadcast ID
224.16.196.xx
1st IP
224.16.196.xx - 224.16.196.xx
Question
Following normal rule re powers of 2, how can we have 30 subnets for this?
Though its classless, can you have a CIDR /25 - /29 on a 126.0.0.0 or 185.0.0.0 range as my numbers don't add up?
And on a separate note.
Does a L2 or L3 switch with vlan's create a collision domain within a network and if so, than what is the point of having a router on a stick scenario then?
Thanks in advance again
22 Replies 22
My ip is 61.49.23.41 /27 (11100000)
2^3 = 8 -2 = 6
2^5 = 32 -2 = 30
32 - CIDR = 27
Network ID 61.49.23.0 /27
61.49.23.1 - 61.49.23.28 BC.29
Network ID 61.49.23.30 /27
61.49.23.31 - 61.49.23.58 BC.59
etc up to BC.255
But when I put that into a subnet calculator
Network ID is 61.49.23.32 /27
Unless network ID start with the magic number but that isn't correct as some end in 0 (zero)
Thanks Julio for the very detailed reply. I was getting confused with the last octet number and the network ID for following subnets. And so the broadcast goes to .224 due to total value of bits borrowed?
I have noted you are subtracting (-2), the substraction should be used to find X amount of hosts using the formula: [(2^n) -2 ], but if you are going to get X amount of subnets the formula is: [2^n] the substraction is not required.
and the formula to know the available bits should be:
32 - CIDR (in this case 27) = 5
Now if your IP is 61.49.23.41 /27, this ip belongs to the network 61.49.23.32/27, why? because the subnet mask is going 32 by 32 on the blocks:
subnet mask /27, it represents 27 active bits:
octet 1 (8 active bits): 11111111  = 255
octet 2 (8 active bits): 11111111  = 255
octet 3 (8 active bits): 11111111  = 255
octet 4 (8 active bits): 11100000  = 224   ((2^7 + 2^6 + 2^5 = 224) You will sum just the active bits (1) the rest of bits are zero's so they are not considered))
Image result for subnetting binary
sum = 27 bits, now with the formula for the blocks you can know how will be blocks (networks)
Formula: 256 - 224 (why 224, because /27 is 224 on the 4th octet) = 32 ; so the blocks will be 32 by 32 on the 4th octet because it was the only octet modified, the other 3 octets were kept the same 255.255.255.224.
Results:
New subnet: 61.49.23.0/27
New subnet: 61.49.23.32/27 <-- valid IP address .33 to .62 so the IP .41 is between this range.
New subnet: 61.49.23.64/27
New subnet: 61.49.23.96/27
New subnet: 61.49.23.128/27
New subnet: 61.49.23.160/27
New subnet: 61.49.23.192/27
New subnet: 61.49.23.224/27   <--- the last subnet
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes it is.
With the last subnet, that finishes at .224 due to that is how many bits were borrowed and you can't go passed that?
Was just trying to find out how many subnets (if any) for /26 - /29 CIDR
Please correct me if Im understanding wrong the question, but if you have 2 subnets:
224.16.196.51 /26
224.16.196.51 /29
It could be used on the same network infrastructure because it will create overlapping unless you create a subnetting for the /26 to get several /29 networks.
From what subnet you would like to get 30 networks?
Julio E. Moisa
Hi John
The key to subnet is know the formulas:
In order to get # of hosts you can use (2^n) - 2
In order to get # of subnets you can use (2^2)
Available bits to subnetting: 32 - CIDR, example  32-24 = 8 bits  <-- you will have 8 bits to subnetting.  32-16 = 16, so you will have 16 bits to subnetting.
Block of networks after subnetting:  256 - value of the subnet mask, example: new subnet mask: 255.255.254.0 so the block will be increasing 2 by 2 on the third octet.  basically is 256 - modified octet value.
Network 172.16.0.0/16
Subnetting to get 2 subnets or 510 hosts.
Network 1 - 172.16.0.0/23
Network 2 - 172.16.2.0/23
Network 3 - 172.16.4.0/23
A collision domain means the part of network where a packet could suffer a collision, the switches divide the collision domains so it decrease the possibility to have problems with the communication, if you have a switch of 24 ports it means you will have 24 collision domains. Now Router in a stick is a method to create intervlan routing, you need a L3 devices like a router, multilayer switch or firewalls in order to communicate 2 or more vlans with each other. So the scheme router in a stick is used for that.
Hope it is useful
