Connect a server with a multi vlan port to a switch
minagamal237
I want to connect a server to a switch. The server should send traffic in multiple VLANs to the switch. The switchport is trunk.
My question is where should the packets be get tagged with the VLAN (since the switchport is trunk)?? does the switch tag the packet according to the source IP? or do i have to tag the packet on the server?
thanks for your assistance in advance
brselzer
If the server is going to have addresses in multiple vlans, the server will have to tag the traffic with the right vlan tag that way we know which vlan the traffic belongs to. As you have done, the switchport configuration will need to be trunk and allow the vlan tags you need from the server.
Here is another support forum on the issue if you want more details.
https://supportforums.cisco.com/t5/lan-switching-and-routing/vlan-require-any-configuration-on-server-side-host-level/td-p/2638110
Hope that helps!
-Bradley Selzer
CCIE# 60833
Thank you so much!!
