Connect a subred to switch with VLAN
ankyrod2006
I want to connect a subred to switch Cisco Catalyst 4503, for this I make the following steps:
- Add a new Vlan
- Add a new interface
- I assign to this new interface the created Vlan
- enables "Ip routing" mode.
- For new vlan interface I assign IP address
and I list
Now, in these steps where I specify or is related the port of the switch that I will connect to subred ?. because in the interface I specify the modulate / and numbers of the interface, not the port.
Some body could help
Thank you in advance.
7 Replies 7
rwyates_2
You must go under the individual interface you want to be on that vlan and configure it.
interface gi 2/0/2
switch port mode access
switchport access vlan yy (yy is your vlan)
Robert
Ok, I already have defined the interface
But, where I specify the port interface to which will be connected my subred ?
Thank you
Once you assign the port to that VLAN it becomes part of that subnet. Any client you put on that port will need to use the address you configured on the switch or a router on the same subnet as the vlan you created as its default gateway so it can communicate with other subnets or vlans.
I send an outline to explain to me better.
I want to communicate from the subred 10.30.0.0 /24 to the subred 192.168.100.0 /24
In the switch I have to specify the route ?
route 192.168.100.0 255.255.255.0 192.168.101.2
sured 192.168.100.0 /24
ROUTE
| interface 192.168.101.2 /24
| port VLAN 2 interface 192.168.101.3 /24
SWITCH
| VLAN 1
Thank you
If both interfaces or vlans are on the switch you will be able to route them as connected. You dod not have to build static routes to each interface on the swithc. Once you assign the IP address and subnet mask to the Vlan it knows that is the interface. Now if you have another router that you are trying to talk to with theother networks. You will have to configure a static route from the router to the switch. One inteface on the router will need to be on a common VLAN on the switch.
If you could send me the configs I can help you more with this.
OK, I created route in the router.
But I have created static route from de switsh to route to comunicate with subnet thats is in the route ?
Sorry in these moments I am not with the switch for send config.
Thank you
