Vlan Inoperability issues
rostoski123
Community Member
Here is the equipment
Layer 3 3560 switch
two vlans:
vlan1 and vlan 20
vlan 1 servers:
gateway is vlan 1 ip
vlan 20 servers:
gateway is vlan 20 ip
Currently vlan 1 or vlan 20 cannot communicate to each other. Vlan 1 cannot ping vlan 20 interface.
I need my vlan 1 servers to be able to connect to my vlan 20 servers. But, disallow vlan 20 servers to directly connect to vlan 1 servers. What am I missing?
Ryan
5 Replies 5
Ryan,
It would help if you post the configuration you are currently using on the 3560 switch.
Assuming both VLAN interfaces are up you should be able to ping the VLAN interfaces from a host on another VLAN. Do you have 'ip routing' enabled in the switch? Verify this by doing a show ip route in the switch.
As far as disallowing the servers on VLAN 20 from not talking to servers on VLAN 1 you may be able to do this by using ACLs.
Sundar
IP Routing is enabled. I really do not want to post my whole config on here.
Both VLAN Interfaces are up.
Do the ports in Vlan 1 need vlan 20 also allowed?
Or something else?
No, the ports connected to hosts don't have to allow the other VLAN i.e access port on vlan 1 need not allow vlan 20 traffic. The switch should route traffic between the VLANs.
Can you make sure the hosts aren't assigned IP from the wrong VLAN block? Make sure the IP/Subnet mask is configured correctly and the access ports connected to servers are on the correct VLANs. Little things like could very well be the problem. If you are using public IP addresses the post the VLAN IP addresses by hiding the first 2 octects.
Sundar
glen.grant
Do a show vlan and make sure both 1 and 20 show active with ports assigned to them .
NIESW3560-48-1#sh run
version 12.2
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
ip subnet-zero
ip routing
login on-failure
no file verify auto
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan internal allocation policy ascending
interface GigabitEthernet0/1
description connected to SERVER
spanning-tree portfast
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/29
description VLAN
switchport access vlan 20
switchport mode access
interface GigabitEthernet0/30
description VLAN
interface GigabitEthernet0/31
description VLAN
interface GigabitEthernet0/32
description VLAN
interface Vlan1
ip address x.x.80.11 255.255.252.0
interface Vlan20
description ATI VLAN
ip address x.x.79.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.80.1
80.1 <----PIX is default route
ip http server
end
The show vlan was correct.. Thanks everyone..
