Connect a WAN port to the switch
Tiago Reis
I'm having a problem that maybe someone can help me.
I need to connect a cisco 881 (wan port) to a firewall but between both devices I have a switch.
Resuming: Cisco881 (WAN port) -> switch -> firewall.
On my wan por I have:
interface FastEthernet4
ip address 10.12.5.1 255.255.255.0
ip helper-address 10.12.2.1
duplex auto
speed auto
But now I cannot ping the pcs connected to the switch, they are also in network 10.12.5...
What can I do to put this working...?
Any help?
Thks
8 Replies 8
cadet alain
where are located these PCs? where is the dhcp server? Are these pc getting ip address via dhcp?
Can you post running of router and switch.
Regards.
Alain.
mrdogantr
     i think your switch dont know your local nw, change default gw on the switch or use nat for switch's ip.
hth
Muammer
Thanks for your fast reply.
The pcs are connected to the switchs, and are getting ip address through DHCP server that is also a pc connected to that switchs.
The switch doesn't have configuration, is a trendet that have just one vlan, you cannot configure it.
When I had the switch directly connected to the firewall it works fine.
But now I need to create a vpn so I put the Cisco (wan port) connected to the switch (I think that I not explain very well at the beginning, the cisco is not between both devices).
The fastethernet ports (0 to 3) are used in a different network, worknig fine (vlan 7)
ip cef
no ipv6 cef
license udi pid CISCO881-K9 sn FCZ1451C4GH
interface FastEthernet0
switchport access vlan 7
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan7
ip address 10.12.7.1 255.255.255.0
ip default-gateway 10.12.5.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip default-network 10.12.5.0
ip route 10.12.5.0 255.255.255.0 FastEthernet4
control-plane
scheduler max-task-time 5000
end
spremkumar
Level 9
Level 9
Hi Tiago
do you have the pcs behind the firewall? do you have all the devices under same vlan if you are connected all of them on the switch?
regds
All the pcs are in the same segment, at this case we can forget the firewall, the problem is
that from cisco I cannot ping the pcs that are in the same switch than the cisco wan port.
There are any problem of connect a wan port to a switch?
Everything seems fine with the port:
Cisco# sh interfaces fastEthernet 4
FastEthernet4 is up, line protocol is up
  Hardware is PQII_PRO_UEC, address is e05f.b915.801a (bia e05f.b915.801a)
  Internet address is 10.12.5.1/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:10, output 00:00:10, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     379 packets input, 40545 bytes
     Received 162 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     198 packets output, 36538 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
Friends,
I found the solution, it was something very weird, it was the first time that I found this problem.
In my troubleshooting procedure, I try to configure the loopback on that interface and...
Cisco(config-if)#loopback
Loopback is a traffic-affecting operation
Cisco(config-if)#no loopback
Cisco(config-if)#exit
Cisco(config)#do ping
*Jan 25 14:07:30.675: %LINK-3-UPDOWN: Interface FastEthernet4, changed state to up
*Jan 25 14:07:31.675: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4, changed state to up
Cisco(config)#do ping 10.12.5.25
Sending 5, 100-byte ICMP Echos to 10.12.5.25, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/1/1 ms
Cisco(config)#
*Jan 25 14:07:37.963: ICMP: echo reply rcvd, src 10.12.5.25, dst 10.12.5.1, topology BASE, dscp 0 topoid 0
Very very strange...
Thanks for your help
Why did you want to use the loopback feature on the interface?
You wanted to use a loopback interface, I suppose which is not the same
loopback (interface)
To diagnose equipment malfunctions between the interface and device, use the loopback command in interface configuration mode. To disable the test, use the no form of this command.
taken from here http://www.cisco.com/en/US/docs/ios/12_2/interface/command/reference/irfinter.html#wp1018171
Regards.
Alain.
I didn't want to use the loopback feature, it seems that the loopback feature was already active on that interface. But it's strange because the sh inter fast 4 don't shows loopback configured.
For lucky I remember to test the interface with the loopback, and when I did the "no loopback" command it works...
