connect layer3 switch
Jose Salazar
Frequent Visitor
Frequent Visitor
Hello guys
I have a network with two layer 3 switch 3560cx and two routers in the middle 4300
I also have a pfsense firewall connected to the first switch which allow to get access to internet.
I can access to internet from all the servers connected to the first switch but not to the pc or servers connected to the last switch.
the first switch has 4 vlans (vlan 10,20,30 and 40) vlan 10 IP is 192.168.1.2/24
I noticed that I can ping from the first switch to the firewall with IP 192.168.1.1/24. I can ping from the last switch to the IP 192.168.1.2 but I cannot ping to the firewall 192.168.1.1.
I implement ospf area 0 in the two switch and also the routers, didn't work
I created a default route with 0.0.0.0 0.0.0.0 192.168.1.1 in the first switch , didn't work.
Please, follow the graph of my network below
I can ping from the first router but no from the second router or the last switch with IP 172.16.5.2
do you have any idea what is missing here?
Yachay
Level 5
Level 5
Assuming OSPF is working fine and the firewall has routes back to those networks, Switch-1 has to be the only device with the default-information originate command. Remove that command from the rest.
johnd2310
Level 11
Level 11
Have you tried adding the default-information originate on switch-1.
John
**Please rate posts you find helpful**
KJ5
Community Member
Do you where I can find a layer 3 template for 3750 just a base template?
thanks
Yachay
Level 5
Level 5
you were right, the routes in the firewall
