Connect nexus 5000 to WS-C3750E-24TD-S
Hello
I have a client that has the following infraestructure:
N5K-C5010P-BF N5000 1RU Chassis no PS 2 Fan Module 20 ports (req SFP)
needs to connect to this switch WS-C3750E-24TD-S 10GB with the following module: X2-10GB-SR =.
My question is possible make that connection?
which module in the Nexus 5000? SFP-10G-SR (=) ?
I can confirm there is a cisco cable to connect the two modules that is 7 meters or more? If the cable did not exist I can confirm what I require is a cable with a tip for LC SFP-10G-SR (=) and the other end SC X2-10GB-SR = with the following features Wavelength (nm ) 850, Core Size (microns) 62.5, Modal Bandwidth (MHz * km) 160 or any of the following cable?
Thanks.
Olga Galindo
Cisco SFP+
Wavelength (nm)
Cable Type
Core Size (microns)
Modal Bandwidth (MHz*km)***
Cable Distance*
Cisco SFP-10G-SR
850
MMF
62.5
62.5
50.0
50.0
50.0
160
200
400
500
2000
26m
33m
66m
82m
300m
To be more clear.  X2 has optical interoperability with respective 10GBASE
SFP+ modules on the same link.
SFP+ datasheet, Table 1:
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/data_sheet_c78-455693.html
X2 datasheet, Table 1.:
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6574/product_data_sheet0900aecd801f92aa.html
Nelson Galimba
You should be able to find what you are looking for in the compatability matrix:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.html
Nelson
