Connect ssh without username
Gabriel Bute
I try to connect on a new IE 1000 switch from a Cisco 809 router.
Default IE1000 on ssh don't have a username and the password is cisco.
when I try to connect from 809 in cli with ssh -l "username" 192.168.1.254 i don't know what must i use in place of "username" to can connect to switch.
Teste_Nat#ssh -l 192.168.1.254
% Incomplete command.
8 Replies 8
Hi @Gabriel Bute
 Dont use the -l.  Just use  "ssh 192.168.1.254"
Thank you.
Unfortunately didn't work:
Teste_Nat#ssh 192.168.1.254
% No user specified nor available for SSH client
Hello @Gabriel Bute,
could you please provide IE21000 vty lines config. ?
Best regards
In first please it is about ie1000 not 2000
Information you request:
line vty 0
line vty 1
line vty 2
line vty 3
line vty 4
line vty 5
line vty 6
line vty 7
It is the default configuration from Cisco
Unfortunately, the switch is on the field and the only acces I have to it is a ssh session.
@Gabriel Bute
Configure vty in the same as on your Cisco 809 router.
Best regards
I cannot because it is on the field with the default factory configuration.
At this moment only ssh connection it is posible from local router, made from office.
