Using SCP to backup your configs safely.
bruce.porter
I have installed SSH to use as an encrypted method of logging onto my routers. It works. I also enabled the SCP server on the cli, router config#ip scp server enable. (be careful here because scp has a slight vulnerability where a user with a restricted view can still use it. This has been fixed in the latest, 20050325 releases).
The thing is that the secure copy protocol is dificult to use. There is no information on either Cisco or other web sites on how to use it to back up configs.
I tried WinSCP, and PuTTY pscp. Neither one seem to work as servers, in other words, you can't initiate SCP transfers from the router to the Windows box with these clients. All I manage to get is errors about sftp or ... when trying to initiate from the windows box.
It may be that you need to use Cisco Works LMS to perform the copy. The SCP server service on the router is embeded and may not completely follow standards for the protocol, or ???
Any ideas?
13 Replies 13
Yudong Wu
Level 7
Level 7
How about you setup a SCP server on PC, and then use "copy" command to transfer file from router to it.
Yes, there might be certain compatibility issue between router SCP server and those third party SCP clients.
very easy as a,b,c:
a- ip domain-name cciesec.com
b- crypto key zerosize rsa
c- crypto key generate rsa -- choose 1024
d- username cciesec privilege 15 pass cisco
e- aaa new-model
f- aaa authentication login default local
g- aaa authorization exec default local
h- line vty 0 4
i- login authentication default
[Expert@NEO-labgw]# scp cciesec@192.168.15.201:running-config .
Password:
running-config 100% 4131 47.4KB/s 00:00
Connection to 192.168.15.201 closed by remote host.
[Expert@NEO-labgw]#
Easy for you.. A couple of questions. Why not use a 2048 key? Got the part about setting up the Cisco device,
a)create a domain name so that the crypto key generate will work,
b)zeroize the old rsa keys on the Cisco box.
c - i) set up the AAA for SSH and SCP.
The next part, what is going on with the following statement:
Password:
Are you entering the SCP service from the Cisco device and sending the running-config to the PC running some kind of SCP server?
Thanks.
Yes, PC is running CentOS Linux version 5.2.
Host "NEO-labgw" is a CentOS Linux box which has scp/sftp built-in by default
Thanks. I was hoping for a Windows solution. It is good to know that you can PULL a running config from a linux box. It looks like the Cisco SCP service on the Cisco box can look like an SCP client to CentOS Linux. thx
My solution also works on Windows solution as well, if you use pscp.exe. One thing to keep in mind is that if you use "pscp.exe" for scp, you need to use the "-pscp" option, like this:
C:\temp>pscp.exe -scp cciesec@192.168.15.201:running-config .
Using keyboard-interactive authentication.
Password:
running-config | 4 kB | 4.0 kB/s | ETA: 00:00:00 | 100%
C:\temp>
Again, easy right?
Still no go.
C:\PuTTY>pscp -scp -v Bruce@192.168.1.1:running-config
Where 192.168.1.1 is the cisco device.
I get the usage info when trying to do it.
PuTTY Secure Copy client
Release 0.60
Usage: pscp [options] [user@]host:source target
pscp [options] source [source...] [user@]host:target
pscp [options] -ls [user@]host:filespec
Options:
-V print version information and exit
-pgpfp print PGP key fingerprints and exit
-p preserve file attributes
-q quiet, don't show statistics
-r copy directories recursively
-v show verbose messages
-load sessname Load settings from saved session
-P port connect to specified port
-l user connect with specified username
-pw passw login with specified password
-1 -2 force use of particular SSH protocol version
-4 -6 force use of IPv4 or IPv6
-C enable compression
-i key private key file for authentication
-noagent disable use of Pageant
-agent enable use of Pageant
-batch disable all interactive prompts
-unsafe allow server-side wildcards (DANGEROUS)
-sftp force use of SFTP protocol
-scp force use of SCP protocol
I had debug enabled on the device but nothing showed up. My guess is that the command never ran on the Windows box.
This is a helpful page on the use of putty:
http://the.earth.li/~sgtatham/putty/0.60/puttydoc.txt
I am getting closer though. I got the following error from putty:
C:\PuTTY>pscp -scp Bruce@192.168.1.1:running-config c:\putty
Bruce@192.168.1.1's password:
Privilege denied.
This also was verified with some debug on the network device. I am set to AAA with 15 privilege. I guess something else is needed for the SCP part..
I know this post is 5 years old, but found it as I ran into the same issue.
For me pscp works now with an ASR1006
C:\PuTTY>pscp -scp -v Bruce@192.168.1.1:running-config .
You forgot the "dot" at the end of your command (cisco24x7 has it in his post). It is essential, as this is for target.
This helped ab bit regarding pscp.
But as you pointed out
did work neither, I asume there was an additional issue with scp server konfig on your router.
Did you solve this in the end?
I know this is an old post, but this method doesn't seem to currently work. ASA version 9.2(4). It looks like the ASA is looking for "running-config" from the flash: or disk0:.  In order to get the running-config you need to call out the "system:" directory first.  This command works for me from a bash command prompt:
scp user@192.168.0.1:system://running-config .
or
scp user@192.168.0.1:system://running-config newfilename.cfg
I verified that this works under recent versions of ASA
config t
  ssh scopy enable
  username foo password secret privilege 15
  username foo attributes
    ssh authentication publickey {paste public key here}
end
Then the following works:
scp foo@test-asa:system://running-config running-config
scp foo@test-asa:startup-config startup-config
--sk
yes. and now he can use ubuntu inside windows 10
fracorbas
This post is old, but it's about an issue I have. I wanted to copy from the switch to my pc the configuration file using scp.
I ran into different errors but finally found a solution and make it work.
I've used openssh for windows (you can install it with optional features Settings => Application => Optional features => search "openssh" and install client and server), after the installation, you have three different folders where the configuration of the ssh server take place :
C:\WINDOWS\System32\OpenSSH => default configuration with executables
C:\ProgramData\ssh => used for connection and keys
C:\Users\<username>\.ssh => user's saved sessions
to get the server starting with your machine, use Win+R and "services.msc". Look for "openssh". There will be the authentication, and the server. Double clic on them, start them and make them start with your machine
Because the ssh serve have to listen to the 22 port, you have to allow it in your microsoft firewall (or phisical firewall, depends on what you're using)
Next, we have to configure the ssh server :
  • first, we have to generate the keys for each file of the second folder, in order to do that, use this command in a administrator shell (cmd) :
    for %f in (%ProgramData%\ssh\ssh_host_*_key) do @%WINDIR%\System32\OpenSSH\ssh-keygen.exe -l -f "%f"
you should have a result showing the generate keys with their respective algorithms (DSA, ECDSA, ED25519, RSA...)
  • I tried to copy the file using scp : copy run scp://<user>:<password>/$h
    at this point i got an error from incompatible Ciphers, to correct it, I added to the C:\ProgramData\ssh\sshd_config the following lines :
    # Ciphers and keyingCiphers
    +aes128-cbc,aes256-cbc,3des-cbc
    KexAlgorithms +diffie-hellman-group14-sha1
    HostkeyAlgorithms +ssh-rsa
    # If you authenticate using a keypair:
    PubkeyAcceptedAlgorithms +ssh-rsa
/!\ Every time you're modifying the config files, go to services.msc and restart both of the services listed above /!\ (permit ssh to reload the new configuration and use it)
  • after trying again to connect, I have an "Authentification Failed" error, to correct it, I added in ~\.ssh\authorized_keys.txt (create it if doesn't exist) the public key of the switch (generated after configuring the ssh on your switch).
    I also changed the line HostbasedAuthentication to yes
After doing so, everything work, the files did copied using scp. You may encouter different errors with the permission that can be solved by changing the rights on each folders.
Hope this will help someone, one day.
windows ssh client: how to fix "no matching cipher found" - Super User
