Connect unmanaged switch to a managed port
akshaycjoshi
I have one SG-300 8 port managed switch and have around 10 d-link unmanaged switches.
Out of them I have to create a network of 5 VLANS (2 unmanaged switch per VLAN).
For each VLAN, I can daisychain 2 unmanaged switches and connect them to a port in managed switch. That port will be assigned to a particular VLAN.
Now how can I configure that managed port such that it will interpret all frames received on that port to be part of that VLAN.
It is neither a access port (because a switch is connected to it) nor trunk (since the connected switch is unmanaged it cant send tagged frames).
I can make a particular VLAN, default VLAN so that untagged frames received on that port will be considered part of default vlan but it cant have a default vlan per port.
I hope my question is clear.
So all ports in Unmanaged1 and Unmanaged2 would belong to VLan2, right ?
That is correct.  And the port that connects to the managed switch will be configured as an access port.
Reza Sharifi
Unmanaged switch1 connects to unmanaged swtch2, and unmanaged switch2 connects to managed switch carrying only one vlan. Then you just need to configure each port on the managed switch as access port.
Port 1(switchport mode Access (VLan2)-->Unmanaged1-->Unmanaged2
Thank you Reza !
