Connecting 100-Base-LX Single Mode-LC to SC
gnanavel.ns
I need some help on connecting a Cisco 3945 Router to an Ethernet WAN Link. The service provider has provided a 100M Ethernet Single Mode Fiber handoff to the customer premises with SC Connector. The CPE configuration proposed for this setup is like this.
Cisco 3945
EHWIC-1GE-SFP-CU      (EHWIC 1 port dual mode SFP(100M/1G) or GE(10M/100M/1G)
GLC-FE-100LX               100BASE-LX SFP  for FE port.
Since the SFP has LC Connector, i suppose i need to have an SC-LC Cable for connecting the Ethernet link. Do i need anything else, apart from above?
Kindly suggest.
Thanks for your time.
Gnan.
sansarav720e
Dear Gnan,
           U need to Procure Fiber patch cable of SC-LC single mode (normally service provider ll provide single mode fiber hand off ) .kindly check with provider whether u want to procure single mode or multi mode fiber type .
     This should do for your requirement .
Thks
Santhosh Sarav
HTH Regards Santhosh Saravanan
Leo Laohoo
Duplicate Post #2.
