Connecting 2 switchtes
avilt
Level 3
Level 3
Sorry for the basic question, we have bought two new Catalyst 2950 switches and to uplink them I used the cross-over cable.
It was not working so I changed it to straight cables which works fine. Is it a normal behaviour. As per my knowledge, to connect 2 similar devices we have to use cross-over cables.
Thank You.
3 Accepted Solutions
Sure it can.  2960/2960S switch ports are MDI/MDI-X.
Yes that is absolutly normal, because both switches support the autonegotiation. If you want to learn more about the behaviour look here:
http://en.wikipedia.org/wiki/Medium_dependent_interface
greets Martin
Oh nuts.  I'm sooooooooooooooo sorry.
The correct command is "sh interface transceiver properties".
Switch#sh int g 2/0/48 trans properties
Diagnostic Monitoring is not implemented.
Administrative Speed: auto
Administrative Duplex: auto
Administrative Auto-MDIX: on
Administrative Power Inline: N/A
Operational Speed: auto
Operational Duplex: auto
Operational Auto-MDIX: on
Media Type: 10/100/1000BaseTX
One more thing:  Do NOT configure speed and duplex setting (leave them in "auto" or default) for MDI/MDI-X to work.
11 Replies 11
Leo Laohoo
2950 do not support MDI/MDI-X so you should use cross-over.
1.  Maybe the 2nd switch is not a 2950 but a newer model.  Perhaps a 2960.
2.  Maybe it's not a straight-through cable.  If you connect the same cable from the switch to a PC or laptop will the link go up?
Sorry, both are Catalyst 2960-S models. One is 24 port and the other one is 48 port.
It works fine with straight cables. Is it a normal behaviour?
greets Martin
How can verify this capability on the switch and why the cross-over cable should not work?
use the command "sh interface cap".
Cross-over or straight-through doesn't matter because the switch supports MDI/MDI-X.
From the following output, how can I verify MDI/MDI-X capability?
SW-24#show interfaces gigabitEthernet 1/0/1 capabilities
GigabitEthernet1/0/1
  Model:                 WS-C2960S-24TS-L
  Speed:                 10,100,1000,auto
  Duplex:                half,full,auto
  Trunk encap. type:     802.1Q
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on,desired),tx-(none)
  Fast Start:            yes
  QoS scheduling:        rx-(not configurable on per port basis),
                                  tx-(4q3t) (3t: Two configurable values and one fixed.)
  CoS rewrite:           yes
  ToS rewrite:           yes
  UDLD:                  yes
  Inline power:          no
  SPAN:                  source/destination
  PortSecure:            yes
  Dot1x:                 yes
SW-24#
Alright,
What is the command to disable MDI/MDI-X feature on the interface if at all possible.
For obvious reasons, the command "no mdix auto" will disable MDI/MDI-X of an interface.  There is, in my experience, no global command available.
Leo Laohoo
Wow!  Someone gave me a 1 star for making the right assumption!
