Connecting 3 switches 1 router - 1 router 3 switches intervlan and sub interface
prince_repollo
R1 same as R2
Current configuration : 1657 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname R1
enable secret 5 $1$mERr$DUtyl1ZjHgzpmSjSaZ/N80
enable password 7 0822455D0A16
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 180.101.24.1 255.255.252.0
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 180.101.0.1 255.255.240.0
interface FastEthernet0/1.30
encapsulation dot1Q 30
ip address 180.101.28.1 255.255.254.0
interface FastEthernet0/1.40
encapsulation dot1Q 40
ip address 180.101.30.1 255.255.255.0
interface FastEthernet0/1.50
encapsulation dot1Q 50
ip address 180.101.16.1 255.255.248.0
interface FastEthernet0/1.101
encapsulation dot1Q 101
ip address 180.101.31.1 255.255.255.224
interface Serial0/0/0
ip address 180.101.31.225 255.255.255.240
clock rate 64000
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 10
log-adjacency-changes
network 180.101.24.0 0.0.3.255 area 110
network 180.101.0.0 0.0.15.255 area 111
network 180.101.28.0 0.0.1.255 area 112
network 180.101.30.0 0.0.0.255 area 113
network 180.101.16.0 0.0.7.255 area 114
network 180.101.31.224 0.0.0.15 area 115
network 180.101.31.0 0.0.0.31 area 116
ip classless
line con 0
login
line aux 0
line vty 0 4
login
end
ALL switches same as this
Current configuration : 2450 bytes
version 12.1
hostname S2
enable password cisco
switchport access vlan 10
switchport mode access
interface FastEthernet0/2
switchport access vlan 101
interface FastEthernet0/3
interface FastEthernet0/4
switchport trunk native vlan 101
switchport mode trunk
interface FastEthernet0/5
switchport access vlan 20
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
switchport access vlan 30
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
switchport access vlan 40
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
switchport access vlan 50
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
description server interface
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
no ip address
shutdown
interface Vlan101
ip address 180.101.31.153 255.255.255.224
banner motd ^C"Authorized Access Only"^C
line con 0
login
line vty 0 4
login
line vty 5 15
login
end
i can't connect pc from router1 to the other pc in router2.. please help
more power
Reza Sharifi
check the default gateways on the PC
